Warning: There may be multiple iterations of this laptop, and each uses a different battery model. Before you purchase a replacement battery, open the back cover up to visually confirm which battery replacement you should purchase.
The battery within a laptop is the most important component to having a functioning laptop. If you are experiencing a poor battery lifetime in your HP Elitebook 840 G5, then please follow the step-by-step replacement guide for the battery below. As this replacement requires the backing to be completely removed, use caution during the replacement as the electrical components inside of your laptop will be exposed. Also ensure to carefully remove any connecting wires by the heads-not the wires themselves. This will prevent any wires from breaking during the replacement.
Use a Phillips #1 screwdriver to undo the five screws. The top three screws are 10 mm and the two side screws are 7 mm.
Unscrew the bottom three screws using the same screwdriver.
Turn computer so that the hinged side is facing up.
Use the plastic opening tool to pry open the back plate.
Drag the plastic opening tool along the edge from left to right and use a second opening tool to pry open the top right corner.
Repeat the 3rd step for the other side.
Repeat on Left and Right sides of the system. There are two points in the middle (on the left and right sides of the center screw) that will release with slight lifting pressure.
Grab the back plate and separate it slowly away from the device.
Remove the 4mm screws that are fastened on the battery with your T9 Torx screwdriver.
Carefully remove the power supply connector by tugging it from the sides of its head.
Slide the battery out and remove it from the device.
no problem replacing the battery. However, the system does not recognize it and does not charge it
crwdns2935229:029crwdne2935229:0
crwdns2947412:07crwdne2947412:0
The battery shown in the photo is a TT03XL. My HP Elitebook 840 G5 laptop has a SS03XL battery. Before you order your replacement battery, take off the laptop’s bottom cover and confirm the battery model you need.
Unfortunately, the TR9 Torx Security Screwdriver did not work on my Elitebook 840 G5. It is unclear if this is due to the battery model. Mine is a SS03XL battery.
Same problem, i ordered battery based on this, but this model have SS03XL battery un TT03XL battery is for Hp EliteBook 850 G5 G6, ZBook 15U G5 G6 Series
I also got caught up in this battery fiasco.
Replaced the battery with the correct SS03XL battery sold from here and have had zero luck in getting it to charge. Updated bios, firmware, everything under the sun, drained the system of residual power. Disconnected CMOS battery because I'm reaching for anything at this point. Bios diag options doesn't even list battery diag as an option. Battery is not detected. I'm at a loss, help pls.
replaced the battery, it works just fine, but struggeling with the touchpad, it no longer gets the proper "click" feel after replacing, battery seems to have the same shape, and thickness, i might try putting in the old one and see if this sovles it, its like its to "tight" around the touchpad area. redid everything 4 times and everything seems to be placed correctly. when back cover is off, it clicks just fine tho.
power mode laptop is any time on but Battery mode some time no on (New Battery)
On my HP EliteBook 840 G5, the “two side screws” (black) are found inside the two holes seen next to the left top screw, and between the center and right top screw.
Ruedi Port - crwdns2934203:0crwdne2934203:0
Mine had the same, and these black screws also need to be released in order to remove the bottom panel.
Josh -
Correct. Some other models have 2 black screws at the back, near the corners.
The models with the 2 black screws, are missing the 2 silver screws at the left side and the right side in the middle.
Note: You need to release the 2 black screws as well, if your type of model has them.
koppie007 - crwdns2934203:0crwdne2934203:0
Thank you this was very helpful. I was able to remove the cover and the SSD.
Stupid question but is this board considered the hard drive? my laptop failed (no power) and I did get an identical replacement. In the past I have been able to remove the hard drive in the failed laptop and connect it to the new one via a data transfer cable (removed hard drive to usb in new laptop. I could then browse files off of the old hard drive and transfer them over to the new. This SSD board has vastly different connectors. Do you know if they make a transfer cable that connects to this board with a usb on the other end?
dgtuk1 - crwdns2934203:0crwdne2934203:0
I removed the back cover and installed a new SSD. When I went to put the back cover, the center screw would not go back in. It turns but does not catch. Any advice?
Erik - crwdns2934203:0crwdne2934203:0
