HP EliteBook 840 Aero G8 Display Panel Replacement
  1. crwdns2944588:01crwdnd2944588:0crwdnd2944588:0crwdne2944588:0
    HP EliteBook 840 Aero G8 Display Panel Replacement, Before you begin: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Before you begin: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
    • Save your work, fully shut down your laptop, and unplug all cables.
  2. HP EliteBook 840 Aero G8 Display Panel Replacement, Unfasten the bottom cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Unfasten the bottom cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
  3. HP EliteBook 840 Aero G8 Display Panel Replacement, Release the bottom cover clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Release the bottom cover clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Release the bottom cover clips: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position your laptop so the rear edge (with the screen hinge) is closest to you.
    • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
    • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
    • Use your spudger to pry up the cover to release the clip securing it.
    • Leave the spudger inserted under the bottom cover for the next step.
  4. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
    • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
  5. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the flat end of a spudger near the ELITEBOOK text.
    • Repeat the previous step for the other side of the cover to release the remaining clips.
  6. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bottom cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bottom cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bottom cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the bottom cover.
    • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
    • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
  7. HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
    • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
  8. HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the WLAN module cables: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the WLAN module cables: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the WLAN module cables: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, located just below the fan.
    • Lift straight up to disconnect the cable.
    • Repeat to disconnect the second connector.
    • During reassembly:
    • Connect the cable with black tape to the socket with a black arrow below it, and the cable with white tape to the socket with a white arrow.
    • Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
  9. crwdns2944590:09crwdnd2944590:011crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grip the plastic pull tab on the right display cable press connector, below the fan.
    • Pull straight up to disconnect the connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again. Don't use excessive force.
  10. HP EliteBook 840 Aero G8 Display Panel Replacement, Peel up the fan tape: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Peel up the fan tape: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to peel up the cable tape near the right side of the fan.
    • You don't need to fully remove the tape—it can stay on the cable.
  11. HP EliteBook 840 Aero G8 Display Panel Replacement, De‑route the fan cables: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, De‑route the fan cables: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, De‑route the fan cables: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the display cable and two coaxial cables out from their clips on the right side of the fan.
    • During reassembly, use this photo as a reference to properly route the cables into their clips.
  12. crwdns2944590:012crwdnd2944590:013crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the power connector cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the power connector cable: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the power connector cable: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger or your fingernail to push on alternating sides of the power connector's sliding connector to walk it completely out of its socket near the left hinge.
    • During reassembly, make sure the side of the connector marked with a black dot is facing up before reconnecting the cable.
  13. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to pull the power connector cable out of its clip.
    • During reassembly, use this photo as a reference to properly route the cable into its clips.
  14. HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to grip the plastic pull tab on the left display cable press connector, near the left hinge.
  15. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to pull the display cable out of its clip.
  16. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or tweezers to lift the display and antenna cables out of their clip near the right hinge.
  17. HP EliteBook 840 Aero G8 Display Panel Replacement, Fully open your laptop: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Fully open your laptop: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Fully open your laptop and set it keyboard-side down on a flat, clean work surface, with the display closest you.
    • During reassembly, if your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
  18. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the hinge screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the hinge screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the six 4.6 mm‑long hinge screws—four in one hinge and two in the other.
    • Before installing any hinge screws, make sure the display is properly aligned.
    • Tighten the hinge screws in ascending order based on the number stamped next to each screw hole.
  19. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display assembly: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display assembly: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display assembly: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the display assembly near the hinges and lift straight up to remove it.
    • You may need to hold down the main body while guiding the hinges out of their recesses.
    • During reassembly, make sure both hinges on your replacement display assembly are fully open before lowering them into their recesses.
  20. crwdns2944590:020crwdnd2944590:035crwdnd2944590:0crwdnd2944590:0crwdne2944590:0
    HP EliteBook 840 Aero G8 Display Panel Replacement, Separate the bezel: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Separate the bezel: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the flat end of a spudger underneath the top edge of the display's plastic bezel, near the top left corner.
    • The plastic bezel is bendable and secures to the display with light adhesive.
  21. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger across the top edge, around the top right corner, and down the right edge to separate the adhesive securing the bezel.
  22. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the spudger across the bottom edge, around the bottom left corner, and up the left edge to separate the adhesive securing the bezel.
  23. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Re-insert the flat end of the spudger underneath the top edge of the display's plastic bezel, near the top left corner.
    • Lift up to peel the bezel away from the display, until you can grip it with your fingers.
  24. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bezel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bezel: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the bezel: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once a portion of the bezel lifts to where you can grip it with your fingers, peel the bezel up around the entire perimeter, using the spudger to separate any sections still adhered.
    • Remove the plastic bezel.
    • During reassembly, make sure to remove all the plastic liners and pieces of tape from your replacement bezel. Check thoroughly around the entire perimeter.
  25. HP EliteBook 840 Aero G8 Display Panel Replacement, Unscrew the chin cover: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Unscrew the chin cover: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the xx mm-long screw securing the chin cover.
  26. HP EliteBook 840 Aero G8 Display Panel Replacement, Unlock the chin cover: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Unlock the chin cover: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the entire chin cover to the right to unlock it.
  27. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the chin cover: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the chin cover: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the chin cover: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the chin cover down and away from the display.
    • Remove the chin cover.
    • Before reinstalling the chin cover, make sure all of the cables along the bottom of the screen are tucked into their recess and over the screen hinges. Use this photo as a reference.
  28. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the screen adhesive strips: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the screen adhesive strips: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The display panel attaches to the shell with two stretch-release adhesive strips.
    • Near the bottom right side of the screen, use a pair of tweezers to peel back the black pull tab on the stretch-release adhesive strip until you can grip it with your fingers.
  29. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab an adhesive strip's pull tab and slowly pull it out from underneath the battery.
    • If using a pair of tweezers, spin the tweezers to wrap the strip up as it releases, pulling as you go.
    • Keep the angle of the adhesive strip as parallel to the display as you can.
    • Pull the adhesive strip until it's freed from under the screen.
  30. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat and remove the adhesive strip from the left side of the screen.
  31. HP EliteBook 840 Aero G8 Display Panel Replacement, Free the display cable: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Free the display cable: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Free the display cable: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the display cable out from underneath its routing tab on the shell.
  32. HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display panel: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display panel: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Remove the display panel: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift and remove the display panel from the shell.
  33. HP EliteBook 840 Aero G8 Display Panel Replacement, Transfer the display cable: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Transfer the display cable: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replacement display panels may or may not come with an included display cable. If it's missing on the replacement, you'll need to transfer the old one over from your original panel.
    • A thin layer of tape covers and protects the display cable connector.
    • Prepare an iOpener and apply it to the screen-side display connector tape for one minute to soften the adhesive.
    • A hair dryer may also be used, but be careful not to overheat the components—keep the hair dryer well above the connector and moving at all times.
  34. HP EliteBook 840 Aero G8 Display Panel Replacement, Peel up the tape: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Peel up the tape: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Peel up the tape: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to push up a corner of the tape until you can grip it with a pair of tweezers.
    • Use a pair of tweezers to peel the tape back, over the connector.
  35. HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Disconnect the display cable: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to lift up the thin metal locking bar on the display connector.
    • Use your fingers to slide the display cable out of its connector.
    • Connect the display cable to your new display.
    • If the tape is sticky enough to reuse, press down to secure it in place over the connector. If it needs to be replaced, cut a section of clear packing tape to fit.
  36. HP EliteBook 840 Aero G8 Display Panel Replacement, Display Panel: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Display Panel: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement, Display Panel: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert wisdom here.
  37. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  38. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  39. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  40. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  41. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  42. HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP EliteBook 840 Aero G8 Display Panel Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
To reassemble your device, follow these instructions in reverse order, starting with the hinge cover step.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
112,142 crwdns2915208:0crwdne2915208:0
crwdns2935297:0811crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,068crwdne2935297:0
crwdns2942667:0crwdne2942667:0 28
