HP EliteBook 745 G4 Battery Replacement
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
    • Disconnect the power from the computer by unplugging the power cord from the computer.
    • Disconnect all external devices from the computer.
    • Turn the computer upside down on a flat surface.
  1. HP EliteBook 745 G4 Battery Replacement, Remove the rubber plugs: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 10 rubber plugs from the bottom cover.
    • Remove the SD card blank from the bottom cover.
  2. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 Phillips PM2.5x5.0 screws in the following order.
    • After you remove the PM2.5×5.0 screws, remove the PM2.0×7.0 screw.
  3. HP EliteBook 745 G4 Battery Replacement, Remove the bottom cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry up on the top (near the display hinge) of the bottom cover to disengage it from the computer. Consider using a spudger.
  4. HP EliteBook 745 G4 Battery Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen the two captive screws and remove the battery from the computer
To replace the battery & reassemble your device, follow these instructions in reverse order.
crwdns2935229:05crwdne2935229:0
Max Kletskov
crwdns2935283:004/22/20crwdne2935283:0
40,916 crwdns2915208:0crwdne2915208:0
The Home Depot crwdns2935289:0The Home Depotcrwdne2935289:0
Community
crwdns2931471:018,494crwdne2931471:0
crwdns2935297:0110crwdne2935297:0
you forgot to put the instructions for after the battery is installed when you boot it up You’ll get non-HP battery detected asking you to press enter on every boot. How is this problem fixed?
Richard B - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 1,722
