Use this guide to replace the battery on the HP Elitebook 1040 G4. The battery is essential for providing power to the laptop. A faulty battery can cause many adverse effects on your laptop experience: from overheating to computer crashes, or even just simple difficulties with charging or holding a charge. Although the battery in this computer is rechargeable, the battery itself may need to be replaced after long and repeated use.
To complete this guide, you will need a T5 Torx head screwdriver and a Phillips #00 screwdriver.
Before beginning, be sure to unplug and completely power off your computer.
Use a T5 Torx screwdriver to remove the eight 5 mm screws securing the back cover to the chassis.
Lift the back cover up and off the device.
Use a Phillips #00 screwdriver to remove the eight 4 mm screws securing the battery to the motherboard.
Use a plastic spudger to carefully disconnect the battery pin connector from its port, slowly lifting the pin connector from each side until it releases.
Lift and remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
