HP Deskjet 1055 Scanner Glass Pane Replacement
  1. HP Deskjet 1055 Scanner Glass Pane Replacement, Scanner Glass Pane: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take all paper out of the paper tray. Unplug the printer.
    • Remove the plastic printer-control panel on the top left.
    • Then, forcefully lift up the bottom of the panel while applying downward pressure with your thumb-as shown.
  2. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With your other hand, slide the top of the panel towards the back of the printer.
    • Do not rip the white cable that connects the panel with the main body of the printer.
    • Disconnect the ribbon by pinching the blue tab and pulling away from the green circuit board.
    • Lift the panel free and set to the side.
  3. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the plastic opening tool between the plastic cover and the mount on the printer.
    • Pry the plastic cover towards the center of the printer.
    • Pull up on the cover to remove it from the printer-as shown.
    • Repeat the process on the other side.
  4. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the glass panel, take out the four 14 mm (1/2 inch) screws with a T10 Torx screwdriver.
    • Don't lift the glass panel completely off because there are cables plugged into the underside.
  5. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the white cables from the green motherboard by pinching the cable where it connects to the green motherboard. Pull up, lightly.
    • Set the lower part of the printer aside.
  6. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the glass panel, face down, on a smooth surface.
    • Remove the 14 mm (1/2 in.) screw from the white plastic tab on the side of the panel with a T10 Torx screwdriver.
  7. HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Deskjet 1055 Scanner Glass Pane Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the glass pane by carefully bending the plastic frame down from the side and sliding the glass pane out from the side.
Samuel Isbell
crwdns2935283:010/09/12crwdne2935283:0
10 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 9-18, Amido Fall 2012 crwdns2935289:0Cal Poly, Team 9-18, Amido Fall 2012crwdne2935289:0
CPSU-AMIDO-F12S9G18
Which dimensions is the glass pane?
123 l - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 4,410
