If the bottom cover of your HP Chromebox is damaged, it is easy to replace. This guide will take you through the steps of replacing the bottom cover. For this guide, you will need the Phillips #1 screwdriver and a plastic spudger.
Position the device upside-down on a flat, level surface with the USB ports facing you.
Using your metal spudger, lift and remove the 4 rubber “feet” from each corner.
Using your Phillips head screwdriver, remove the four Phillips M2.5×4.0 screws that secure the bottom cover to the computer. In this step the usage of the magnetic mat will be helpful to keep up with the screws.
Insert the flat end of your metal spudger under the bottom cover near the USB ports, then pry the bottom cover off the computer.
Can you explain how/where the integrated VESA mount is?
Is the mounting screw holes under the rubber feet, like other chromeboxes, from other makers?
both for the cover replacement and shield replacement
Ian Stoffel - crwdns2934203:0crwdne2934203:0
For the hard drive replacement, a longer times should be indicated. for the WLAN replacement 15 minutes is indicated, but for the hard drive replacement, which can only be done after the WLAN replacement, the time is listed as 10 minutes.
