HP Chromebook 14-SMB SSD Replacement
  1. HP Chromebook 14-SMB SSD Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Lay the laptop down with the lower case facing up.
    • Remove eleven screws using a Phillips screwdriver.
    • Remove the two rubber stoppers, then remove the two Phillips screws.
  2. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-SMB SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open the lid.
    • Insert an opening pick into the seam between the keyboard and chassis.
    • Slide the opening pick a few centimeters along the seam to begin to release the clips.
    • Once there's enough space in the seam, insert an opening tool into the seam.
    • Pry around the entire perimeter of the keyboard until it fully releases.
  3. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-SMB SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard perpendicular to the laptop.
    • Flip up each of the the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
    • Disconnect the keyboard and trackpad ribbon cables.
    • Remove the keyboard.
  4. HP Chromebook 14-SMB SSD Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
  5. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three screws that secure the battery.
  6. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out of the chassis.
    • Take care not to scratch or damage the battery. Lithium-Ion batteries can be dangerous if punctured.
  7. HP Chromebook 14-SMB SSD Replacement, SSD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three Phillips screws that secure the motherboard.
  8. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-SMB SSD Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP Chromebook 14-SMB SSD Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernails or the flat end of a spudger to disconnect the speaker and fan connectors from their motherboard sockets.
    • Flip up the black ZIF locking flaps of any ribbon cables connected to the motherboard.
    • Disconnect the ribbon cables.
    • Use your fingernails to disconnect the white connector on the underside of the motherboard.
  9. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two wireless card antenna cables.
    • Pull the wireless card directly out of its motherboard port.
  10. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-SMB SSD Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the motherboard a few millimeters to the right to unseat the ports from the chassis.
    • Turn the motherboard over.
    • Remove the single Phillips screw that secures the SSD.
    • The SSD will flip up a few millimeters after removing the screw. This is normal.
  11. HP Chromebook 14-SMB SSD Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the SSD directly out of its motherboard port.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cole Simpson
crwdns2935283:002/19/25crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-3, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-3, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G3
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 188
