Before replacing your HP Chromebook 14-SMB fan, consider other methods to improve cooling functions listed on HP's help center: https://h30434.www3.hp.com/t5/Notebook-B...
Use this guide to replace a faulty fan in a HP Chromebook 14-SMB to avoid overheating and ensure proper performance. In addition to overheating, symptoms of a broken fan in a HP Chromebook 14-SMB can include: unexpected shutdowns, poor performance, and or potential hardware failure. Anyone can complete this repair as it is moderately difficult and requires one tool, a Phillips screwdriver.
Lay the laptop down with the lower case facing up.
Remove eleven screws using a Phillips screwdriver.
Remove the two rubber stoppers, then remove the two Phillips screws.
Flip the laptop over and open the lid.
Insert an opening pick into the seam between the keyboard and chassis.
Slide the opening pick a few centimeters along the seam to begin to release the clips.
Once there's enough space in the seam, insert an opening tool into the seam.
Pry around the entire perimeter of the keyboard until it fully releases.
Lift the keyboard perpendicular to the laptop.
Flip up each of the the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
Disconnect the keyboard and trackpad ribbon cables.
Remove the keyboard.
Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
Use a Phillips #0 screwdriver to remove the three screws that secure the battery.
Lift the battery up and out of the chassis.
Remove three Phillips screws that secure the fan.
Dislodge the cables around the fan from their retaining hooks.
Use your fingernail or the flat end of a spudger to disconnect the fan connector from its motherboard socket.
Lift the fan up and out of the chassis.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
