HP Chromebook 14-SMB Battery Replacement
  1. HP Chromebook 14-SMB Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Lay the laptop down with the lower case facing up.
    • Remove eleven screws using a Phillips screwdriver.
    • Remove the two rubber stoppers, then remove the two Phillips screws.
  2. HP Chromebook 14-SMB Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-SMB Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and open the lid.
    • Insert an opening pick into the seam between the keyboard and chassis.
    • Slide the opening pick a few centimeters along the seam to begin to release the clips.
    • Once there's enough space in the seam, insert an opening tool into the seam.
    • Pry around the entire perimeter of the keyboard until it fully releases.
  3. HP Chromebook 14-SMB Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP Chromebook 14-SMB Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard perpendicular to the laptop.
    • Flip up each of the the two black ZIF locking flaps that secure the keyboard and trackpad ribbon cables to their motherboard sockets.
    • Disconnect the keyboard and trackpad ribbon cables.
    • Remove the keyboard.
  4. HP Chromebook 14-SMB Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernail or the flat end of a spudger to gently disconnect the battery connector from its motherboard connector.
  5. HP Chromebook 14-SMB Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three screws that secure the battery.
  6. HP Chromebook 14-SMB Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery up and out of the chassis.
    • Take care not to scratch or damage the battery. Lithium-Ion batteries can be dangerous if punctured.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Cole Simpson
crwdns2935283:002/19/25crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-3, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-3, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G3
crwdns2942667:0crwdne2942667:0 72
