HP Chromebook 11 G5 DC Charging Port Replacement
  1. HP Chromebook 11 G5 DC Charging Port Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four large rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  2. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two smaller rubber pads from the bottom of the device to reveal screws using the pointed end of a spudger.
  3. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4mm eleven screws using a Phillips #00 screwdriver.
  4. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device upright and open the screen as far back as possible.
  5. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the flat-end of a metal spudger between the base of the device and the keyboard assembly while applying downward pressure. Slide the spudger across the entirety of the gap until the two components separate.
    • There will be audible popping sounds caused by the separation of the base of the device and the keyboard assembly as you wedge them apart.
    • Do not insert the spudger into the gap deeper than necessary as it may snag on the internal components.
  6. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the keyboard assembly slightly above the base of the device.
  7. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the two ribbon cables connected to the motherboard by using the pointed end of a spudger to lift the plastic connector lids to allow the ribbon cables to be gently removed by hand.
  8. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the keyboard assembly by hand from the base of the device.
  9. HP Chromebook 11 G5 DC Charging Port Replacement, DC Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the charging port cable from the motherboard using your finger or a spudger and gently pull it off.
  10. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws from the hinge of the device using a Phillips #00 screwdriver.
    • Carefully lift the hinge up.
  11. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the charging port cable with the hinge up to remove the DC charging port.
  12. HP Chromebook 11 G5 DC Charging Port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the DC charging port from the base using a spudger.
Salma Zitoun
crwdns2935283:001/14/20crwdne2935283:0
385 crwdns2915208:0crwdne2915208:0
York University, Team S1-G3, Woodhouse Winter 2020 crwdns2935289:0York University, Team S1-G3, Woodhouse Winter 2020crwdne2935289:0
YORK-WOODHOUSE-W20S1G3
I thought it was going to be a little bit more difficult than it was . I got it done in about 15-20 minutes. Thanks to this.
Maryann Charles - crwdns2934203:0crwdne2934203:0
Do you guys sell these replacement DC Ports or know where to find them? (I work for a school, but the students keep breaking things! I need, like, 25 of these… yep, it’s that bad. Even found a literal nest of cockroaches inside one of them. I still have the picture/video of it for the morbidly curious lol.)
Aaron Yamauchi - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,504
