HP 15-fc0000 Series Display Panel Replacement
  1. HP 15-fc0000 Series Display Panel Replacement, Power off the laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Shut down the laptop.
    • Unplug the charger and any other cables from the laptop.
  2. HP 15-fc0000 Series Display Panel Replacement, Remove the bottom cover screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop and flip it over so the rubber feet are facing up. Place the laptop on a soft surface to avoid damaging the top cover.
    • Use a Phillips screwdriver to remove the four screws securing the bottom cover.
    • Two 6.8 mm‑long screws near the rear of the laptop.
    • Two 4.8 mm‑long screws near the front of the laptop.
  3. HP 15-fc0000 Series Display Panel Replacement, Release the bottom cover clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Release the bottom cover clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The clips attached to the bottom cover are fragile. Use caution when releasing them.
    • Insert an opening pick under the bottom cover at the rear of the laptop.
    • Twist the pick until one or more clips release.
    • Repeat this procedure along the rear edge until you release all the clips.
  4. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bottom cover is fragile. Use caution when bending it.
    • Place your fingers under the part of the bottom cover you've raised, near a corner.
    • Use your fingers to gently pry up the corner of the bottom cover.
  5. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the edge of the bottom cover next to the corner you've raised.
    • Pry up the back cover clips along the edge.
  6. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to repeat the procedure from the previous step to pry up the remaining sides of the bottom cover.
  7. HP 15-fc0000 Series Display Panel Replacement, Remove the bottom cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the bottom cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the bottom cover.
    • Some clips may re-engage when you're releasing other sides. If the bottom cover doesn't lift off easily, use the opening pick to release any remaining clips.
    • During reassembly, lay the bottom cover on the laptop so the sides of the cover align with the sides of the laptop. Then, gently press on the sides until you hear the clips click. If the clips don't engage easily, adjust the cover and try again.
  8. HP 15-fc0000 Series Display Panel Replacement, Lift the speaker wire tape: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the speaker wire tape: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not put too much stress on the wire, as that can harm your laptop's audio quality.
    • Use a spudger or your fingers to lift the tape that adheres the speaker wires to the metal trackpad bracket.
    • Try not to fold the tape so it can be reused during reassembly.
  9. HP 15-fc0000 Series Display Panel Replacement, Move the speaker wires: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Move the speaker wires: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Move the speaker wires: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to remove the speaker wires from the routing clips along the edge of the battery.
  10. HP 15-fc0000 Series Display Panel Replacement, Remove the battery screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the battery screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 4.3 mm‑long screws securing the battery.
    • During reassembly, press firmly on the battery connector to ensure a strong connection.
  11. HP 15-fc0000 Series Display Panel Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the battery: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not grab the battery at the ends because this battery is flexible. Instead, grab the battery one inch from each end to better support the middle.
    • Use two hands to grip the battery about one inch from each end.
    • Lift the front of the battery (the side closest to you) until the battery is free of its alignment pegs.
    • Pull the battery towards you to release it from its connector.
    • Don't continue to use a damaged battery, as doing so is a potential safety hazard. If in doubt, replace it with a new battery.
    • During reassembly, insert the battery onto its connector at a slight downward angle before pressing it flat to the frame.
  12. HP 15-fc0000 Series Display Panel Replacement, Remove the right hinge screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the right hinge screws: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The right hinge is on the left side since the laptop is upside down
    • Use a Phillips screwdriver to remove the three 5.6 mm‑long screws securing the right hinge.
  13. HP 15-fc0000 Series Display Panel Replacement, Open the right hinge: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Open the right hinge: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the left hinge to 90º so it's pointing upward.
  14. HP 15-fc0000 Series Display Panel Replacement, Remove the left hinge screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the left hinge screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The left hinge is on the right side since the laptop is upside down
    • Use a Phillips screwdriver to remove the three 5.6 mm‑long screws that securing the left hinge.
  15. HP 15-fc0000 Series Display Panel Replacement, Open the left hinge: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Open the left hinge: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  16. HP 15-fc0000 Series Display Panel Replacement, Disconnect the display: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Disconnect the display: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up the locking tab on the display cable ZIF connector.
  17. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers or your fingers to grip the black taped portion of the display cable.
    • Pull the ribbon cable away from its connector to disconnect it.
    • When reconnecting this cable, make sure the locking tab is fully open (up). The cable should slide in with minimal force. If you feel resistance, check that the locking tab is fully open and the cable is aligned, then try again.
  18. HP 15-fc0000 Series Display Panel Replacement, Lift the display cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the display cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to lift the display cable up and out of its routing channel.
  19. HP 15-fc0000 Series Display Panel Replacement, Remove the wireless LAN antenna cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the wireless LAN antenna cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the plastic cover on the wireless LAN card antenna cable.
    • Set the plastic cover aside with the sticky side up.
    • Keep the adhesive on the back of the plastic cover clean, as you will reuse this during reassembly.
  20. HP 15-fc0000 Series Display Panel Replacement, Disconnect the wireless LAN antenna: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Disconnect the wireless LAN antenna: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place one arm of a pair of tweezers under the metal head of the antenna cable. Lightly grip the head.
    • The pictured laptop only has one antenna cable, but yours may have two.
    • Lift straight up to disconnect the antenna.
    • It's important to lift the connector straight up. If lifted at an angle, you risk breaking the socket off of the board underneath.
    • During reassembly, use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  21. HP 15-fc0000 Series Display Panel Replacement, Lift the wireless LAN antenna cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the wireless LAN antenna cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the wireless LAN antenna cable: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, a spudger, or fingers to lift the wireless LAN antenna out of the routing clips beside the fan.
  22. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to move the wireless LAN antenna from underneath the plastic arm that holds it down.
    • If your DC‑in cable is on top of your wireless LAN antenna cable, gently pull it out from underneath the DC-in cable before proceeding.
  23. HP 15-fc0000 Series Display Panel Replacement, Remove the frame: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the frame: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the frame: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the frame of the laptop so it is at 90º to the display assembly.
    • Slide the frame towards the webcam until it's free from the hinges.
    • Make sure the display cable and wireless LAN antenna are out of the way from the frame.
    • Now you're left with the display assembly for replacement.
  24. HP 15-fc0000 Series Display Panel Replacement, Separate the bezel: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Separate the bezel: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The bezel is thin and can be broken easily. Work slowly, and don't lift the bezel at sharp angles.
    • Insert an opening pick on the inside of one of the thinner sides of the display bezel, between the bezel and the display panel.
    • Cut the adhesive by sliding the opening pick along the display bezel.
    • The pick should slide easily. If it's difficult, you may be separating the conductive tape on the display panel. Take your pick out and re-insert it in a different location, trying to insert it at as low of an angle as possible.
  25. HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the perimeter of the bezel until all of the adhesive is cut.
    • The bottom of the display bezel (the side with the HP logo) is wider. The entire width is secured with adhesive, so you'll need to insert the opening pick further.
  26. HP 15-fc0000 Series Display Panel Replacement, Lift the bezel: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the bezel: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the clips holding the display bezel by gently lifting the bezel, starting with one of the thinner sides.
    • The bezel is thin. To avoid breaking it, if it is difficult to remove, use the opening pick to slice any adhesive that may have become reattached.
  27. HP 15-fc0000 Series Display Panel Replacement, Remove the bezel: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the bezel: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $8.99
    • Lift the bezel and slide it out from underneath the hinges to remove it.
    • The bezel can be replaced without applying new adhesive. However, if your new bezel includes new adhesive, use isopropyl alcohol (>90%) and a lint-free cloth to remove any adhesive residue from the display panel.
    • You may also apply new adhesive, such as Tesa tape, to create a better seal.
  28. HP 15-fc0000 Series Display Panel Replacement, Remove the left adhesive: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the left adhesive: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the left adhesive: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The display panel is secured with stretch-release adhesive, which may break if you pull too quickly, or at too high of an angle. Follow these instructions closely and take your time to avoid breaking the adhesive.
    • Use a pair of pointed tweezers to grip the pull tab below the lower-left corner of the screen and pull it up slightly so it's above the display assembly.
    • Slowly pull the adhesive straight back at a low angle until all of the adhesive is separated.
  29. HP 15-fc0000 Series Display Panel Replacement, Remove the right adhesive: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the right adhesive: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the pull tab of the stretch‑release adhesive below the lower‑right corner of the display panel, then repeat the procedure from the previous step to remove this adhesive.
  30. HP 15-fc0000 Series Display Panel Replacement, Lift the display panel: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Lift the display panel: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display panel from the top of the panel (the side closest to the webcam).
    • Hold the panel at 90º or prop it against something sturdy for the next step.
  31. HP 15-fc0000 Series Display Panel Replacement, Remove the display cable tape: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the display cable tape: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the display cable tape: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the display panel panel is being held or propped up at 90º, use a pair of tweezers to remove the fabric tape covering the display cable connector on the back of the display panel.
    • Keep this tape clean so it can be reused during reassembly.
  32. HP 15-fc0000 Series Display Panel Replacement, Disconnect the display cable: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Disconnect the display cable: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to lift the locking buckle over the display connector.
  33. HP 15-fc0000 Series Display Panel Replacement, Remove the display panel: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the display panel: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-fc0000 Series Display Panel Replacement, Remove the display panel: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to grip the display cable and the buckle.
    • Holding the display cable in place, lift the display panel to disconnect it from the display cable.
    • Remove the display panel.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Spencer Pennington
crwdns2935283:009/09/23crwdne2935283:0
21,759 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Staff
crwdns2935297:023,259crwdne2935297:0
Cant you just replace the screen without removing the entire display from the computer? People do that on many videos.
Alexander Olsson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 544
