HP 15-dw0037wm Battery Replacement
  1. HP 15-dw0037wm Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dw0037wm Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dw0037wm Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dw0037wm Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the the four 4 mm screws that secure the battery.
  5. HP 15-dw0037wm Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery out slowly to disconnect it from the socket that connects it to the motherboard.
    • Removing the battery quickly can damage the socket that the motherboard is connected to.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Emily Davila
crwdns2935283:008/28/24crwdne2935283:0
651 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S1G5
crwdns2942667:0crwdne2942667:0 285
