If your HP 15-dw0037wm laptop is having issues holding charge or if the battery is draining fast, it may be time to get a battery replacement. The battery provides power to your device when it’s not plugged into an outlet, and over time, its capacity can degrade after numerous charges. If you find that it fails to charge properly, it’s a sign that the battery may be reaching the end of its lifespan. Before beginning the battery replacement, make sure to power down your device.
Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
Set the laptop down with the lower case facing up.
Lift a corner of the lower silicone foot and peel it completely off.
Repeat for the upper silicone foot.
Use a Phillips screwdriver to remove the five 8 mm screws.
Remove the two 5 mm Phillips screws.
Insert an opening pick into the gap between the lower case and chassis.
Slide the pick around the entire perimeter of the device until the lower case fully releases.
Remove the lower case.
Use a Phillips screwdriver to remove the the four 4 mm screws that secure the battery.
Lift the battery out slowly to disconnect it from the socket that connects it to the motherboard.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Donde encontrar esa batería?
