Turn off your laptop and flip it upside down onto a flat surface.
Slide the battery lock tabs towards each other to unlock the battery.
Lift the battery from the center and remove.
Align the new battery with the cut-out in the laptop.
Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
Use your Phillips screwdriver to remove the 10 screws in the bottom cover.
Flip the computer back over and use an opening tool to pry the keyboard up from the bottom of the computer.
Once the keyboard is removed, locate the fan.
Use your Phillips screwdriver to remove the two screws on either side of the fan.
Unplug the wire that is connected to the fan.
Remove the fan.
