Turn off your laptop and flip it upside down onto a flat surface.
Slide the battery lock tabs towards each other to unlock the battery.
Lift the battery from the center and remove.
Align the new battery with the cut-out in the laptop.
Insert the battery into it slot until you hear a "click" indicating the battery is fully seated.
Use your Phillips screwdriver to remove the 10 screws from the bottom case.
Flip your laptop back over and lift open the screen so it is perpendicular to the keyboard.
Use an opening tool to pry the keyboard up from the bottom case.
Slide the CD drive out of the bottom case.
