HP 15 Series Hard Drive Replacement
  1. HP 15 Series Hard Drive Replacement, Remove rubber feet, screws, and optical drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15 Series Hard Drive Replacement, Remove rubber feet, screws, and optical drive: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 10 same-sized Philips screws.
    • Use a tiny flathead screwdriver to pry the rubber feet off, and remove each of the screws under where the rubber feet were. These screws, as you may notice, are longer than the others.
    • For reassembly, use school glue to glue the rubber feet back on. Don't forget the screws!
    • Slide out the optical drive, if there is one.
  2. HP 15 Series Hard Drive Replacement, Remove keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop on its side, optical drive hole up, and use a nice n' long spudger to push the keyboard out through the hole above where the optical drive was. Light always helps to pinpoint the hole.
    • Once the keyboard starts popping up, get under it with your fingers and pull.
    • Don't slide your fingers along the underside of the keyboard, you are likely to get cut! I learnt that the hard way as I made this guide. Owie.
    • On a side note, don't put the screws right in the path of where the keyboard comes out. I lost almost every screw in the picture because of that.
    • Set the laptop down to normal position, unlock the keyboard connector, and remove the keyboard cable from the connector.
  3. HP 15 Series Hard Drive Replacement, Remove palmrest: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15 Series Hard Drive Replacement, Remove palmrest: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws securing the palmrest to the base.
    • Remove the touchpad and power button cables from their connectors.
    • Flip the laptop bottom-up, and remove the remaining two screws holding the palmrest.
  4. HP 15 Series Hard Drive Replacement, Remove hard drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Normally, there will be two screws holding the hard drive (or, in this case, solid state drive) in, but in this case, the screws are missing, and the SSD slid out from the connector. The computer wasn't showing any drive, and hence, it was brought in for me to repair.
    • Remove the two screws securing the hard drive to the base.
    • You're done!
Joseph Sctbunio
crwdns2935283:009/23/17crwdne2935283:0
7 578 crwdns2915208:0crwdne2915208:0
crwdns2935297:042crwdne2935297:0
Laptop refuses to power on at all after this, just gives a 6 second blink of the power LED and the F12 LED when the power button is pressed. No screen backlight, no fan noises, no light under the power button...
rp12345 - crwdns2934203:0crwdne2934203:0
Laptop refuses to power on at all after this, just gives a 6 second blink of the power LED and the F12 LED when the power button is pressed. No screen backlight, no fan noises, no light under the power button... Anyone know what could be wrong? All ribbon cabels reseated properly, and used ESD protective wrst strap during procedure throughout.
The laptop itself magically started working again after a few more cycles of disassembly and re-assembly. No clue how, but it runs now and seems to be back in good health. Didn't do anything differently between the times it failed to power on when reassembled and the time it just started working again, but it works now.
rp12345 -
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 185
crwdns2942667:0crwdne2942667:0 8,754
