HP 14-fq1025nr Ports Replacement
  1. HP 14-fq1025nr Ports Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Ports Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Ports Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Ports Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Ports Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom cover.
  6. HP 14-fq1025nr Ports Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-fq1025nr Ports Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Ports Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  8. HP 14-fq1025nr Ports Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Ports Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Ports Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan.
  11. HP 14-fq1025nr Ports Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-fq1025nr Ports Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-fq1025nr Ports Replacement, Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  12. HP 14-fq1025nr Ports Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-fq1025nr Ports Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the wire connections.
    • Use tweezers if needed.
  13. HP 14-fq1025nr Ports Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  14. HP 14-fq1025nr Ports Replacement, Ports: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
Alex Cutler
crwdns2935283:009/26/22crwdne2935283:0
301 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-6, McMurrin Fall 2022 crwdns2935289:0Utah Tech University, Team 1-6, McMurrin Fall 2022crwdne2935289:0
UTAHTECH-MCMURRIN-F22S1G6
crwdns2942667:0crwdne2942667:0 185
