HP 14-dq5043cl Wi-Fi Module Replacement
  1. HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
    • Remove the two rubber feet on the lower case.
    • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
  2. HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six M2XL6 Phillips screws that secure the lower case.
  3. HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a nylon spudger into the seam between the lower case and chassis.
    • Pry around the entire perimeter until the lower case fully releases.
    • Remove the lower case.
  4. HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single M2x6.5 screw that secures the Wi-Fi module.
  5. HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pointed end of a spudger to lift and disconnect the two Wi-Fi module coaxial connectors.
  6. HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-dq5043cl Wi-Fi Module Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the Wi-Fi module directly out of its socket to remove it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
crwdns2935283:002/19/25crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 17-2, Thornton Spring 2025 crwdns2935289:0Sam Houston State, Team 17-2, Thornton Spring 2025crwdne2935289:0
SHSU-THORNTON-S25S17G2
crwdns2942667:0crwdne2942667:0 65
