Does your HP 14-dq5043cl struggle to power on, hold a charge for long periods of time, or die randomly? If that's the case, you may have a faulty battery that is in need of a replacement.
A laptop battery is one of the primary components responsible for providing power to the device. If compromised your device will not be operable. Our goal is to provide a comfortable and simple experience to replace this essential part.
Before you begin make sure your device is powered off and not plugged in.
Remove the two rubber feet on the lower case.
Remove the six M2XL6 Phillips screws that secure the lower case.
Insert a nylon spudger into the seam between the lower case and chassis.
Pry around the entire perimeter until the lower case fully releases.
Remove the lower case.
Remove the four Phillips screws that secure the battery.
Grip the lower edge of the battery and pull it toward you to disconnect the blade-style battery connector.
Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
