If your HMDX Chill is having any kind of issue this guide will show how to disassemble the device in order to begin the process of fixing your issues.
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
Grip the base of the HMDX Chill.
Pull the base upwards.
I still need help here. Problem not fixed
Lornejanes1@gmail.com
Thank you
I have jam zero chill. One year old. Very very little use. Maybe 3 to 4 hours total.
Plug in to charge red light comes on solid and goes out in couple of hours. Then light flashes red and zero chill will not connect.
Thank you
