HMD Pulse Pro Vibration Motor Replacement
  1. HMD Pulse Pro Vibration Motor Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. HMD Pulse Pro Vibration Motor Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    • During reassembly, use the tray's markings to orient and reinsert it properly.
  3. HMD Pulse Pro Vibration Motor Replacement, Separate the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Separate the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of an opening pick between the back cover and frame, at the SIM card tray cutout.
  4. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the opening pick straight down and slide it along the left edge to begin unclipping the back cover.
  5. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as a delicate cable still connects it to your phone.
  6. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly squeeze around the perimeter to reengage all the clips.
  7. HMD Pulse Pro Vibration Motor Replacement, Remove the motherboard cover: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the motherboard cover: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be very careful not to puncture the battery with your screwdriver.
    • Use a Phillips screwdriver to remove the nine 3.6 mm‑long screws securing the motherboard cover.
    • The screw near the center of the top edge is covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  8. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick between the right edge of the motherboard cover and frame.
    • Twist the pick to fully unclip the cover.
  9. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard shield and its connected graphite sheet.
    • During reassembly, set the motherboard shield into place and press down firmly around the perimeter to reengage the clips.
  10. HMD Pulse Pro Vibration Motor Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the battery press connector from the bottom edge of the motherboard.
    • To reconnect these type of connectors, align the connector over its socket and press down with your fingertip—first at one side, then the other—until it clicks into place. Don't try to force the connector into place, or you may permanently damage it.
  11. HMD Pulse Pro Vibration Motor Replacement, Remove the back cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the back cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and disconnect the back cover press connector from the bottom edge of the motherboard.
  12. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
  13. HMD Pulse Pro Vibration Motor Replacement, Remove the charging board cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the charging board cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the seven 3.6 mm‑long screws securing the charging board cover.
    • The screw near the center of the bottom edge is covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  14. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to lift the bottom edge of the charging board cover until it unclips.
    • Remove the cover.
  15. HMD Pulse Pro Vibration Motor Replacement, Disconnect the charging board: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Disconnect the charging board: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the charging board cable press connector on the top edge of the board.
  16. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one arm of a pair of tweezers under the metal neck of the black antenna cable's connector head, near the center of the board.
    • Lift straight up to disconnect the cable.
    • To reconnect the cable, hold the metal head over its socket and press down with the flat end of a spudger—it should snap into place. If it's not connecting, reposition the head and try again.
  17. HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and unclip the left and right edges of the charging board.
  18. HMD Pulse Pro Vibration Motor Replacement, Remove the charging board: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the charging board: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the charging board.
    • During reassembly:
    • Make sure the interconnect cable is flipped up and the black antenna cable is routed through its groove on the right edge.
    • Set the charging board into its recess and press down on the edges to clip it into place.
  19. HMD Pulse Pro Vibration Motor Replacement, Remove the vibration motor: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the vibration motor: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Pulse Pro Vibration Motor Replacement, Remove the vibration motor: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • Insert the point of a spudger under the left side of the vibration motor (near the small notch) and pry it up.
    • If the motor isn't budging, use a pipette or syringe to apply a drop of isopropyl alcohol (>90%) under the motor to soften the adhesive.
    • Remove the vibration motor.
    • During reassembly, use a small piece of double-sided tape to secure the vibration motor to the frame.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
118,540 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,541crwdne2935297:0
crwdns2942667:0crwdne2942667:0 234
