HMD Fusion Screen Replacement
  1. HMD Fusion Screen Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. HMD Fusion Screen Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Remove the SIM card tray: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
  3. HMD Fusion Screen Replacement, Remove the back cover screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Remove the back cover screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Remove the back cover screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
  4. HMD Fusion Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
  5. HMD Fusion Screen Replacement, Unclip the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Fusion Screen Replacement, Unclip the back cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
  6. HMD Fusion Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge to begin unclipping the back cover.
  7. HMD Fusion Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
  8. HMD Fusion Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
  9. HMD Fusion Screen Replacement, Disconnect the battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Disconnect the battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Disconnect the battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  10. HMD Fusion Screen Replacement, Disconnect the power button: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Disconnect the power button: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Disconnect the power button: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
  11. HMD Fusion Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMD Fusion Screen Replacement, Screen: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For the next step, you'll need to hold the graphite sheet out of the way of the display connector along the bottom of the motherboard.
    • Alternatively, you can use tape with light adhesive (such as painter's tape) to keep the graphite sheet out of the way.
  12. HMD Fusion Screen Replacement, Disconnect the display: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Fusion Screen Replacement, Disconnect the display: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the display press connector.
    • Pry under the right edge of the connector, as there are delicate surface‑mounted components to the left of it.
  13. HMD Fusion Screen Replacement, Separate the front camera: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Fusion Screen Replacement, Separate the front camera: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up the front camera from the frame and separate its adhesive.
  14. HMD Fusion Screen Replacement, Remove the screen screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Fusion Screen Replacement, Remove the screen screws: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T3 Torx screwdriver to remove the seven 3.3 mm‑long screws securing the screen:
    • Five screws on the motherboard
    • Two screws on the loudspeaker
    • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
  15. HMD Fusion Screen Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMD Fusion Screen Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the screen off the frame, making sure to thread the display cable through its slot.
    • Remove the screen.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
167,813 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,702crwdne2935297:0
Wo kann ich ein Ersatzdisplay bestellen? (Bin aus der Schweiz)
Ivan Haedo - crwdns2934203:0crwdne2934203:0
Will the parts ever be in stock in Europe? Pointless to buy a repairable phone when you can't buy the parts
Ejrj - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 299
crwdns2942667:0crwdne2942667:0 3,421
