Use this guide to replace a cracked or damaged back cover on your HMD Fusion Business phone.
Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
Remove the SIM card tray.
Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
Use your fingernails, or angled tweezers, to remove any stuck screws.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Flip your phone over so the screen is facing up.
Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
Slide the opening pick along the left edge to begin unclipping the back cover.
Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
Carefully flip your phone over so the back cover is facing up.
Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
Use a spudger to pry up and disconnect the battery press connector.
Use a spudger to pry up and disconnect the power button press connector.
Remove the back cover.
Use the tip of a spudger to lift the two rubber arms securing the power button out of their slots in the back cover.
Lift the power button out of the recess in the back cover and remove it.
