Applies to H4D engine only.
This is a simple method of cleaning the throttle body without removing it. It is sufficient in most cases and offers remarkable results. Because of its simplicity and the short time it takes, it is advisable to carry out this operation every time the air filter is changed.
The vehicle must be on a slight upward slope or slightly elevated so that the front is tilted upwards and the rear (engine) is tilted downwards.
The aim is to allow fluid and impurities to drain naturally from the throttle body.
Open the trunk.
Put aside the trunk carpets.
Unscrew the 6 T50 screws by hand or using a wrench and a socket.
Lift and put aside the engine hood.
Using a screwdriver, loosen the two Torx T25 screws on the air filter cover.
Remove the cover by moving it forward and then lifting it.
Disconnect the oil vapour breather.
Loosen the hose clamp on the pipe leading to the throttle body using a flathead screwdriver.
Remove the pipe and airbox cover. Set the filter aside if it is to be used again later.
Spray brake or contact cleaner on the throttle and use a soaked paper towel to clean it until the body and edges are clean.
Allow to dry for a few minutes before refitting the airbox.
il faut un nettoyant moins sec que le nettoyant frein ex; nettoyant carbu ou nettoyant vanne EGR. ca nettoie mieux et ça laisse un film gras.
Replace the pipe as far as it will go.
Tighten the clamp screw with a flathead screwdriver while holding the pipe in its correct position.
Reinstall the air filter.
Replace the cover by sliding it towards the notches.
Re-tighten the two Torx T25 screws while maintaining slight pressure on the cover.
Turn it on and off a few times in a row, letting the learning sequence unfold entirely each time.
Once the engine has started, allow some time for the computer to find its new idle position. Help the engine with the throttle pedal if it verges on stalling.
Congratulations ! You have just cleaned your throttle body !
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Ce tuto ne fonctionne pas pour le Tce90. Le boîtier papillon n'est pas accessible.
En effet vous avez raison ! Je vais préciser que ce tutoriel est uniquement applicable au moteur H4D.
