H4D: Cleaning throttle body without dismantling
  1. H4D: Cleaning throttle body without dismantling, Accessing the engine hood: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the trunk.
    • Put aside the trunk carpets.
  2. H4D: Cleaning throttle body without dismantling, Acessing the engine compartment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. H4D: Cleaning throttle body without dismantling, Remove the air filter housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 H4D: Cleaning throttle body without dismantling, Remove the air filter housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a screwdriver, loosen the two Torx T25 screws on the air filter cover.
    • Remove the cover by moving it forward and then lifting it.
  4. H4D: Cleaning throttle body without dismantling, Clear the air duct: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 H4D: Cleaning throttle body without dismantling, Clear the air duct: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the oil vapour breather.
    • Loosen the hose clamp on the pipe leading to the throttle body using a flathead screwdriver.
    • Remove the pipe and airbox cover. Set the filter aside if it is to be used again later.
  5. H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 H4D: Cleaning throttle body without dismantling, Cleaning the throttle valve: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Spray brake or contact cleaner on the throttle and use a soaked paper towel to clean it until the body and edges are clean.
    • It is recommended to wear gloves while handling the break cleaner.
    • Allow to dry for a few minutes before refitting the airbox.
    • When the ignition is switched on, the throttle valve defaults to the idle position, but it can be opened fully by holding the accelerator pedal to the stop.
    • If the accelerator pedal is released, even slightly, the throttle will close, risking cuts to fingers and damage to the gearbox motor!
    • Replace the pipe as far as it will go.
    • Tighten the clamp screw with a flathead screwdriver while holding the pipe in its correct position.
    • Reinstall the air filter.
    • Replace the cover by sliding it towards the notches.
    • Re-tighten the two Torx T25 screws while maintaining slight pressure on the cover.
    • The throttle position sensor is set when the ignition is switched off (you will hear a click/click sequence from the throttle). Using an OBD tool is not necessary. The only function available fully resets all parameters, and requires the following step in any case.
    • Turn it on and off a few times in a row, letting the learning sequence unfold entirely each time.
    • Depending on how dirty the throttle body initially was, the first restart after cleaning is very likely to fail, even if the engine was warm. This is completely normal.
    • Once the engine has started, allow some time for the computer to find its new idle position. Help the engine with the throttle pedal if it verges on stalling.
Congratulations ! You have just cleaned your throttle body !
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
AntonioTwingo
crwdns2935283:008/24/22crwdne2935283:0
7,448 crwdns2915208:0crwdne2915208:0
crwdns2935297:045crwdne2935297:0
Ce tuto ne fonctionne pas pour le Tce90. Le boîtier papillon n'est pas accessible.
Bibard - crwdns2934203:0crwdne2934203:0
En effet vous avez raison ! Je vais préciser que ce tutoriel est uniquement applicable au moteur H4D.
AntonioTwingo -
Bonjour idem pour moi même modèle que bibard
Patou Prevel - crwdns2934203:0crwdne2934203:0
Bonjour, avez-vous la solution pour nettoyer le boîtier papillon pour Twingo 3 année 2017 90 TCE essence ? Merci
crwdns2936751:024crwdne2936751:0 19
crwdns2936753:07crwdne2936753:0 193
crwdns2936753:030crwdne2936753:0 672
crwdns2942667:0crwdne2942667:0 16,123
