If your Gourmia GAF536 air fryer is plugged in and not turning on, a faulty power cord could be the cause. This guide will provide a nice and easy way to replace your power cord. There are no complicated tools required for this project.
Unscrew two 14mm x 6mm screws on bottom of air fryer with Ph 02 screwdriver.
Once both screws are out, the cover piece can be removed.
Unscrew the two 14mm x 5 mm screws covering the wire.
Use a pair of scissors, cut off zip ties around wire.
Be sure to use electrical scissors, cut red and blue wires.
The faulty power chord can then be removed.
Why no photo of the revealed cable connection?
