Google Pixel Slate Speaker Replacement
  1. Google Pixel Slate Speaker Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement, Screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement, Screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement, Speaker: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel Slate Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now remove the speaker from the device.
Spencer Alonge
crwdns2935283:004/18/19crwdne2935283:0
669 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G5, Maness Spring 2019 crwdns2935289:0Cal Poly, Team S2-G5, Maness Spring 2019crwdne2935289:0
CPSU-MANESS-S19S2G5
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 990
