Google Pixel 9 Pro Fold Lower Board Replacement
  1. Google Pixel 9 Pro Fold Lower Board Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold Lower Board Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  3. Google Pixel 9 Pro Fold Lower Board Replacement, Separate the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Separate the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Separate the adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
  4. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick around the top right corner and stop before the front camera.
  5. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
  6. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
  7. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
  8. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
  9. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the display cable bracket screw: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the display cable bracket screw: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
  10. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
  11. Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the display cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the display cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the display cable: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
  12. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the screen: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the screen off the frame and remove it.
  13. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the battery bracket screw: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the battery bracket screw: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
  14. Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the battery: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
  15. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  16. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the bottom interconnect cable bracket screws: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the bottom interconnect cable bracket screws: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
  17. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the bottom interconnect cable bracket from the lower board.
  18. Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the bottom interconnect cable: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Disconnect the bottom interconnect cable: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a spudger under the right edge of the bottom interconnect cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the bottom interconnect cable.
  19. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the SIM card tray: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the SIM card tray: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the SIM card tray: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole and press firmly to eject it.
    • Remove the SIM card tray.
  20. Google Pixel 9 Pro Fold Lower Board Replacement, Reposition the bottom interconnect cable: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reposition the bottom interconnect cable: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • During the next step, you'll need to hold the bottom interconnect cable out of the way. Alternatively, you can use tape with a light adhesive, like painter's tape, to secure the cable to the side of the phone.
  21. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the lower board: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the lower board: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the lower board: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to lift up the top right corner of the lower board and unclip it from the frame.
    • Remove the lower board.
  22. Google Pixel 9 Pro Fold Lower Board Replacement, End of disassembly: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  23. Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the lower board: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the lower board: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the lower board: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the bottom edge of the lower board against the frame at a downward angle to engage its metal spring.
    • Press the board flat to the frame, making sure the screw holes are aligned.
  24. Google Pixel 9 Pro Fold Lower Board Replacement, Reinsert the SIM card tray: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinsert the SIM card tray: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinsert the SIM card tray: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the lower board in place, reinsert the SIM card tray.
  25. Google Pixel 9 Pro Fold Lower Board Replacement, Reconnect the bottom interconnect cable: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the bottom interconnect cable press connector.
  26. Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the bottom interconnect cable bracket on the lower board and align its screw holes.
  27. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
  28. Google Pixel 9 Pro Fold Lower Board Replacement, Reconnect the flip battery: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the flip battery press connector.
  29. Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the flip battery bracket: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the flip battery bracket: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lay the flip battery bracket over the press connector and align the screw holes.
  30. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 2.0 mm‑long screw securing the battery bracket.
  31. Google Pixel 9 Pro Fold Lower Board Replacement, Remove the old adhesive: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Remove the old adhesive: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  32. Google Pixel 9 Pro Fold Lower Board Replacement, Compare your new adhesive: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Compare your new adhesive: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
  33. Google Pixel 9 Pro Fold Lower Board Replacement, Apply the new adhesive: crwdns2935265:033crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Apply the new adhesive: crwdns2935265:033crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Apply the new adhesive: crwdns2935265:033crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
  34. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
  35. Google Pixel 9 Pro Fold Lower Board Replacement, Apply the new adhesive: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Apply the new adhesive: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
  36. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
  37. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  38. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  39. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  40. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  41. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
  42. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
  43. Google Pixel 9 Pro Fold Lower Board Replacement, Reconnect the outer screen: crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reconnect the outer screen: crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
  44. Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the outer screen cable bracket: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Reinstall the outer screen cable bracket: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
  45. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
  46. Google Pixel 9 Pro Fold Lower Board Replacement, Expose the adhesive: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Expose the adhesive: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Expose the adhesive: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
  47. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
  48. Google Pixel 9 Pro Fold Lower Board Replacement, Secure the outer screen: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement, Secure the outer screen: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the outer screen over the frame and press it into place.
  49. Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold Lower Board Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
178.784 crwdns2915208:0crwdne2915208:0
crwdns2935297:0829crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022.175crwdne2935297:0
crwdns2942667:0crwdne2942667:0 161
