Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement
  1. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
  2. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
  3. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the back cover adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
  4. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
  5. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
  6. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
  7. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the top bracket screw: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the top bracket screw: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
  8. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the top bracket: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the top bracket: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
  9. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the back cover cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the back cover cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
  10. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the back cover: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back cover off the frame and remove it.
  11. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the base battery bracket screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the base battery bracket screws: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
  12. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the base battery bracket: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
  13. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the base battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the base battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
  14. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the USB-C port board cable: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the USB-C port board cable: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
  15. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the vibrator bracket screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the vibrator bracket screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
  16. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the vibrator bracket: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the vibrator bracket: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
  17. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the antenna cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the antenna cable: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
  18. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera bracket screws: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera bracket screws: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
  19. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera bracket: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
  20. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the inner front camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the inner front camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the inner front camera press connector.
  21. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner front camera: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
  22. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the ultra wideband antenna: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
  23. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the ultra wideband bracket screws: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the ultra wideband bracket screws: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
  24. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the ultra wideband bracket: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
  25. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the bottom interconnect cable bracket screw: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the bottom interconnect cable bracket screw: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
  26. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the bottom interconnect cable bracket: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
  27. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner display cable bracket screw: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner display cable bracket screw: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
  28. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner display cable bracket: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the inner display cable bracket: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
  29. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the inner display cable: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
  30. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
  31. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the graphite sheet: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the graphite sheet: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
  32. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
  33. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the side buttons: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the side buttons: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
  34. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
  35. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
  36. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the 5G mmWave antenna: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the 5G mmWave antenna: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
  37. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the logic board screws: crwdns2935265:037crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the logic board screws: crwdns2935265:037crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
  38. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the logic board: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
  39. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
  40. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Clean the thermal paste: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
  41. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:041crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
  42. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Disconnect the 5G mmWave antenna: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the 5G mmWave antenna press connector.
  43. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the 5G mmWave antenna adhesive: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the 5G mmWave antenna adhesive: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Separate the 5G mmWave antenna adhesive: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Adhesive secures the 5G mmWave antenna cable on both sides of the logic board.
    • Slide the flat end of a spudger under the 5G mmWave antenna cable's adhered section on the bottom of the logic board
    • Pry up the cable to separate the adhesive.
    • Use tweezers, or your fingers, to pull the cable off the logic board and separate any remaining adhesive.
  44. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:044crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the 5G mmWave antenna cable's adhered section on the top of the logic board.
    • Remove the 5G mmWave antenna.
  45. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, End of disassembly: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  46. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Compare your replacement adhesive with your old adhesive. Make sure you have the right adhesive strips.
    • Use tweezers, or your fingers, to remove the old adhesive off the 5G mmWave antenna cable and its spots on the logic board.
  47. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
  48. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply new adhesive: crwdns2935265:048crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply new adhesive: crwdns2935265:048crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the curved adhesive strip from its opaque liner to expose the adhesive underneath.
  49. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:049crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:049crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the curved adhesive strip over the same‑shaped section of the 5G mmWave antenna cable and press it in place.
  50. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:050crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:050crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:050crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous two steps for the square‑shaped adhesive strip, placing it over the gold section on the 5G mmWave antenna cable.
    • Remove the colored liners from both of the adhesive strips to expose the adhesive underneath.
  51. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the 5G mmWave Antenna: crwdns2935265:051crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the 5G mmWave Antenna: crwdns2935265:051crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the 5G mmWave Antenna: crwdns2935265:051crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the 5G mmWave antenna cable.
    • Wrap the cable around its original spot on the logic board and pinch it to re-adhere both sides.
  52. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply new thermal paste: crwdns2935265:052crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply new thermal paste: crwdns2935265:052crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply new thermal paste: crwdns2935265:052crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
  53. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the logic board: crwdns2935265:053crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the logic board: crwdns2935265:053crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
  54. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:054crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:054crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
  55. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the side button cable: crwdns2935265:055crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the side button cable: crwdns2935265:055crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use angled tweezers to push the side button cable back into its slot.
  56. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:056crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the locking tab down and lightly press on it until it clicks into place.
  57. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:057crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:057crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the yellow tape over the ZIF connector and its cable.
  58. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new graphite sheet: crwdns2935265:058crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new graphite sheet: crwdns2935265:058crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new graphite sheet: crwdns2935265:058crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
  59. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:059crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:059crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
  60. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:060crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:060crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
  61. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:061crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:061crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:061crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
  62. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:062crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:062crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:062crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
  63. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the right side cables: crwdns2935265:063crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the right side cables: crwdns2935265:063crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the right side cables: crwdns2935265:063crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
  64. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner display cable bracket: crwdns2935265:064crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner display cable bracket: crwdns2935265:064crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
  65. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:065crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:065crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
  66. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:066crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the bottom interconnect cable bracket: crwdns2935265:066crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
  67. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:067crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:067crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
  68. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the ultra wideband bracket: crwdns2935265:068crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the ultra wideband bracket: crwdns2935265:068crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
  69. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:069crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:069crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
  70. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:070crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:070crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Replace the ultra wideband bracket adhesive: crwdns2935265:070crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
  71. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:071crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:071crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:071crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
  72. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:072crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:072crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:072crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
  73. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:073crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:073crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:073crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
  74. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:074crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:074crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:074crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
  75. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner front camera: crwdns2935265:075crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner front camera: crwdns2935265:075crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
  76. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner front camera bracket: crwdns2935265:076crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner front camera bracket: crwdns2935265:076crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the inner front camera bracket: crwdns2935265:076crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
  77. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:077crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:077crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
  78. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the antenna cable: crwdns2935265:078crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
  79. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the vibrator bracket: crwdns2935265:079crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the vibrator bracket: crwdns2935265:079crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the vibrator bracket on the logic board and align its screw holes.
  80. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:080crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:080crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
  81. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the USB-C port board cable: crwdns2935265:081crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the USB-C port board cable press connector.
  82. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the base battery: crwdns2935265:082crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the base battery press connector.
  83. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the base battery bracket: crwdns2935265:083crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the base battery bracket: crwdns2935265:083crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
  84. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:084crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:084crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
  85. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:085crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the old adhesive: crwdns2935265:085crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
  86. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the back cover liners: crwdns2935265:086crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the back cover liners: crwdns2935265:086crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the back cover liners: crwdns2935265:086crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
  87. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:087crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:087crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:087crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the remaining clear liners on the outside of the back cover.
  88. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Compare your adhesive: crwdns2935265:088crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Compare your adhesive: crwdns2935265:088crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before removing any liners, check if the adhesive matches the frame.
    • The clear liner should face the frame.
  89. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:089crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:089crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Apply the new adhesive: crwdns2935265:089crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
  90. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:090crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:090crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
  91. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:091crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:091crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:091crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
  92. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:092crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:092crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:092crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
  93. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:093crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:093crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:093crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  94. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reconnect the back cover cable: crwdns2935265:094crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  95. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the top bracket: crwdns2935265:095crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Reinstall the top bracket: crwdns2935265:095crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
  96. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:096crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:096crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
  97. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the secondary liner: crwdns2935265:097crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Remove the secondary liner: crwdns2935265:097crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
  98. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:098crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:098crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:098crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the secondary liner to expose the adhesive.
  99. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Secure the back cover: crwdns2935265:099crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement, Secure the back cover: crwdns2935265:099crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Align the top edge of the back cover with the frame and press down to adhere it.
  100. Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:0100crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:0100crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Pixel 9 Pro Fold 5G mmWave Antenna Replacement: crwdns2935265:0100crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press along the perimeter of the back cover to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
Congratulations on completing your repair!
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
189,047 crwdns2915208:0crwdne2915208:0
crwdns2935297:0866crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:023,251crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 485
