Google Home Motherboard Replacement
Maya Wharton
crwdns2944107:0crwdnd2944107:0Maya Whartoncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Kho 18, 2018crwdne2944111:0
20 - 25 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide involves removing the o-ring from around the casing, unscrewing the casing, and unscrewing the motherboard from the case.
crwdns2944105:0crwdne2944105:0
  1. Google Home Motherboard Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Google Home Motherboard Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Google Home Motherboard Replacement, Interconnect Cable: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Motherboard Replacement, Mute Button Switch: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Motherboard Replacement, Mute Button Switch: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Google Home Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
Maya Wharton
crwdns2935283:004/17/18crwdne2935283:0
184 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S24-G11, Maness Spring 2018 crwdns2935289:0Cal Poly, Team S24-G11, Maness Spring 2018crwdne2935289:0
CPSU-MANESS-S18S24G11
Where can one purchase a replacement motherboard?
Jim Pflasterer - crwdns2934203:0crwdne2934203:0
Most likely the only place to do so would be through contacting Google, as there is no parts sold at retail, only full units
Nick Bergstrom -
crwdns2942667:0crwdne2942667:0 3,391
