A guide to change Google Home Mini USB power port.
Place device on a flat surface.
Remove the rubber bottom as per the Google Home Mini teardown guide.
Remove the four 7mm T6 Torx screws from the bottom.
Remove the lower half of the device.
Black ribbon cable broken. Is there any chance to fix it. Please help. Thank you
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
What if this breaks off. Can i direct connect power.
Where to buy it please tell please
Remove the three 5.3mm T6 Torx screws from the board.
Remove the black metal plate from the board.
crwdns2935229:09crwdne2935229:0
crwdns2947412:09crwdne2947412:0
Where I can buy micro USB PCB ?
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Has anyone had any luck buying a replacement part?
Just broke mine :-(
Is anyone managed to find a place to buy one?
If you're able to solder, you can find micro USB ports on Digi-Key.
Forgot to confirm the pin count while mine was taken apart, but would bet it's similar to many common ports such as PN: 10118194-0001LF
Somebody know where to buy it?
To me it looks like PS4 controllers have a very similar usb port. I'm just about to try one of them..
