Garmin eTrex Vista H LCD screen Replacement
crwdns2942287:0crwdne2942287:0These instructions will teach you how to replace your LCD screen.
Flip the device to the backside, and locate the metal tab at the center of the back cover.
Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
Lift the battery plate off to either insert or remove 2 AA batteries.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
Gently pull the wire ribbon from the white connector.
It is easy to pull the ribbon cable off, but reinserting the ribbon cable back into the wire connector is very challenging. Any tips?
After removing the motherboard, locate the two #1 Philips screws.
Carefully remove both screws.
Gently remove the LCD screen from the case by lifting the area that held the two #1 Philips screws.
Insert the new LCD screen in the device.
Hi, Sir, i need display units for garmin etrexH, and etrex10, please let me k now the unit cost and where i can buy...thanks
Hi, I was wondering where I could get one new screen for my garmin etrex legend HCx.
Thank you very much,
Jordi
Hi there…Could you please help…Looking for a replacement LCD screen for a Garmin Venture Etrex? Kind regards….
leon.visagie75@gmail.com
where can I find the LCD test
