There are times when the power button might fall off the device. If that happens, refer to this guide in order to replace it.
Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Hi, my mom has a Garmin Nuvi 50lm and it’s missing a power button! Is there a way to order a new one? It’s for a Garmin Nuvi 50lm.
Great question, I have same problem. Lots of advice on how to replace it but no-0ne can tell me where to get a replacement power switch. Just wondering if you've had any luck.....CHEERS
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
