Garmin Nuvi 200 Speaker Replacement
  1. Garmin Nuvi 200 Speaker Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Speaker Replacement, Rear Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Garmin Nuvi 200 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two T5 Torx screws.
  3. Garmin Nuvi 200 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Nuvi 200 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Garmin Nuvi 200 Speaker Replacement, Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    there is no use showing how to replace a speaker in nuvi if we cant find any
    seems like a god dam mistery
    Jean Michel Tche - crwdns2934203:0crwdne2934203:0
  5. Garmin Nuvi 200 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the cable out to detach the speaker from the logic board.
  6. Garmin Nuvi 200 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Nuvi 200 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Anjelica
crwdns2935283:004/11/10crwdne2935283:0
564 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-90, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-90, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G90
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - crwdns2934203:0crwdne2934203:0
Where can you buy replacement speakers for the Garmin units?
Brat Fry - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,169
