In this guide the repairer replaces the speaker of the device by disassembling the device further to expose the motherboard and speaker.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
- Fine Point Tweezers
- Spudger
Estimated Duration: 10 minutes
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
The motherboard will now freely separate from the back casing; lay it flat next to the housing.
Detach blue speaker cable from motherboard.
Detach speaker from casing and insert new, functional speaker.
