Garmin Forerunner 25 Battery Replacement
Dustin Persohn
crwdns2944107:0crwdnd2944107:0Dustin Persohncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 8, 2024crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937585:0crwdne2937585:0
crwdns2942287:0crwdne2942287:0
Battery replacement is a common fix for devices as they age. This fix is quick and easy with the use of a T5 screwdriver.
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
crwdns2944105:0crwdne2944105:0
  1. Garmin Forerunner 25 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the old battery out using a plastic spudger.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Dustin Persohn
crwdns2935283:003/21/18crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
IUPUI, Team S5-G3, Baechle Spring 2018 crwdns2935289:0IUPUI, Team S5-G3, Baechle Spring 2018crwdne2935289:0
IUPUI-BAECHLE-S18S5G3
crwdns2947412:011crwdne2947412:0
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - crwdns2934203:0crwdne2934203:0
I need to know as well. What kind of battery is it? PD…????
girlie_360 - crwdns2934203:0crwdne2934203:0
Just look at the last picture. PD2430C1
Leandro Lind - crwdns2934203:0crwdne2934203:0
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - crwdns2934203:0crwdne2934203:0
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - crwdns2934203:0crwdne2934203:0
Hello Adam
im trying to give life to my watch again...Are you sure is pd2032c1 the recommended battery for Garmin forerunner 25.
lookikg forward for your answer
thank you
Al Gkit -
The battery I took out of my Forerunner25 is PD2430C1.
Tony Fleck -
La bateria del Forerunner 25 grande (rojo o azul) es PD2430C1, exactamente la misma que en el Edge 20/25
Jorge Maella - crwdns2934203:0crwdne2934203:0
I just replaced the battery in my Forerunner 25. It was as easy as described in the above instructions. I bought the special screwdriver and pry tool from Ifixit, and bought the exact battery that was listed in the picture (While some other batteries are interchangeable, the original battery has a greater capacity). I bought the battery from another vendor and paid about $20 for it so if Ifixit sells the battery, I would buy it from them to save on shipping. The replacement took about 5 minutes, and after the initial charge, I have run over 16 miles without recharging, and it is still showing that I have about an 80% charge. Before replacement I couldn't complete 8 miles on a full charge without getting a low battery warning. When I called Garmin support about a year ago to find out if they would replace the battery, they said no, that I should buy a new watch. I am ecstatic that I didn't take their advice. My recommendation: Buy the two tools from Ifixit and the battery, either from them or someone else.
Dennis Dennis - crwdns2934203:0crwdne2934203:0
hello Dennis..i have the same issue with my forerunner 25 garmin watch...!i dont want to buy a new ....!!would give me the link to order exactly the same battery please.?
and just for advice .the rightbattery is pd2430c1 or pd2032
thank you my friend Dennis
Al Gkit -
Thanks for the review and info. Garmin told me the same thing to buy a new watch. I'm ordering the battery and tool today.
Tony Fleck -
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 7,553
