Garmin Fenix 3 GPS Antenna Replacement
Adam Estabrook
crwdns2944107:0crwdnd2944107:0Adam Estabrookcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 22, 2024crwdne2944111:0
crwdns2931287:05crwdne2931287:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
If your GPS is failing to find your location, lags, or performs oddly, you can use this guide to locate and replace the antenna, which is located inside the watch. To do this, you will need a T6 Torx screwdriver and a spudger. Tweezers are best used for extracting the GPS antenna.
crwdns2944105:0crwdne2944105:0
  1. Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Fenix 3 GPS Antenna Replacement, Display Assembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 GPS Antenna Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 GPS Antenna Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 GPS Antenna Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Set the watch face aside.
    Hi can i replace only lcd because my sapphire glass is ok
    Drazen Popadic - crwdns2934203:0crwdne2934203:0
  5. Garmin Fenix 3 GPS Antenna Replacement, GPS Antenna: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 GPS Antenna Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the antenna, and set it aside.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Adam Estabrook
crwdns2935283:009/07/18crwdne2935283:0
1,103 crwdns2915208:0crwdne2915208:0
Appalachian State University, Team S1-G3, Menagarishvili Fall 2018 crwdns2935289:0Appalachian State University, Team S1-G3, Menagarishvili Fall 2018crwdne2935289:0
APSU-MENAGARISHVILI-F18S1G3
crwdns2947412:08crwdne2947412:0
Hi, where did you get a replacement Antenna?`I have a Fenix 3 with no GPS reception at all..
Regards, Nico
Nico Baumgartner - crwdns2934203:0crwdne2934203:0
Same as you…
X PuyA -
Hi, where did you get a replacement Antenna? I have a Fenix 3 with no GPS reception at all..
Regards, Dusan
dusan.kosobud - crwdns2934203:0crwdne2934203:0
Could you please add a link where to buy the antenna?
marco475 - crwdns2934203:0crwdne2934203:0
Bonjour, Idem, après plusieurs semaines de recherche pourquoi mon GPS ne fonctionne plus j'ai voulu changer cette pièce mais je ne la trouve pas !
Christopher Dufourmentel -
Indeed where can I but a Gps antenna for Fenix 3hr?
Billou david - crwdns2934203:0crwdne2934203:0
Has anyone managed to find a source for a Fenix gps antenna? thanks in advance for any help
CLIVE ECKETT - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 6,203
