Garmin Edge 530 Battery Replacement
Lainey Merriwether
crwdns2944107:0crwdnd2944107:0Lainey Merriwethercrwdnd2944107:0crwdnd2944107:0crwdnd2944107:04crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Maw 10, 2024crwdne2944111:0
25 - 55 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This guide will show you how to access, remove, and replace the battery of a Garmin Edge 530 device.
It may be necessary to replace the battery if the device is not turning on, or if the device has been damaged. You should troubleshoot to determine that the screen is operating properly before resorting to battery replacement.
The Garmin Edge 530 operates using a lithium-ion battery. This battery part can come as an individual battery or pre-packaged in a back case. If the part you order includes a back case, you should refer to the back case replacement guide for further instruction.
In this guide, you will have to pry up the glass panel with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
A punctured battery can cause a fire. If the battery is swollen, it should be handled properly.
Before beginning, power down the device and disconnect from any external power sources.
crwdns2944105:0crwdne2944105:0
  1. Garmin Edge 530 Battery Replacement, LCD Screen Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
  2. Garmin Edge 530 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
  3. Garmin Edge 530 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
  4. Garmin Edge 530 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
  5. Garmin Edge 530 Battery Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
  6. Garmin Edge 530 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
  7. Garmin Edge 530 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
  8. Garmin Edge 530 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
  9. Garmin Edge 530 Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
    • Fully remove the orange ribbon cable from the charging port.
    What is the replacement battery for the edge 530
    Dave allen - crwdns2934203:0crwdne2934203:0
  10. Garmin Edge 530 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon halberd spudger to peel the battery from the adhesive holding it into the back case.
    • Gently pry up the edges of the battery.
    • Once the adhesive has been separated from the battery, carefully lift it out of the back case.
Lainey Merriwether
crwdns2935283:002/22/22crwdne2935283:0
638 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-1, Hunter Spring 2022 crwdns2935289:0Clemson, Team 2-1, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S2G1
crwdns2935297:017crwdne2935297:0
how is the screen glued back in?
Peter Gee - crwdns2934203:0crwdne2934203:0
You might use the T-8000 glue
Andrea Castellani -
How do those 3 cables get reattached? Do they need to be soldered or are they just pushed back into the black clip?
paulbreslin1983 - crwdns2934203:0crwdne2934203:0
How do those 3 cables go back in, just push into bracket? Do they need to be soldered?
crwdns2936751:024crwdne2936751:0 31
crwdns2936753:07crwdne2936753:0 212
crwdns2936753:030crwdne2936753:0 909
crwdns2942667:0crwdne2942667:0 22,406
