Garmin Edge 530 Back Cover Replacement
crwdns2869540:0crwdne2869540:0: 6.9 k
9
59
224
6,894
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:035crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
Use this guide to remove and replace the back cover of the Garmin Edge 530. The back case is a protective cover enclosing all of the inner hardware of the Garmin Edge 530. Removing it is a key step in gaining access to the rest of the device. Accessing the back cover allows you to replace any internal part. Similarly, replacing the back cover requires the removal of every internal part. Only take on this replacement task if you feel confident in your ability to exercise patience and caution in the removal of replacement parts.
The back case may need to be replaced if the case is cracked or damaged. Damage to the back case can limit your ability to mount the Garmin Edge 530 device which limits useability.
In this guide, you will have to pry up the front screen with a metal spudger. It is important to note the potential broken glass hazard when prying the screen from the back cover. After this step, use ESD-safe tools to avoid damage to the rest of the device and protect it from electrostatic discharge.
    1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the metal spudger between the edge of the device screen and back cover.
      • Begin to pry along the perimeter between the device screen and back cover.
    2. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Halberd Spudger
      $2.99
      • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
      • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    3. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    4. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
      • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    1. Garmin Edge 530 Back Cover  Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      Halberd Spudger
      $2.99
      • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
      • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    2. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    3. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Take the motherboard out of the back cover.
      • You will remove the wire harness in the next step.
    4. Garmin Edge 530 Back Cover  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Edge 530 Back Cover  Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      $3.99
      • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
      • Now the motherboard and compartment are separated.
    1. Garmin Edge 530 Back Cover  Replacement, Back Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
      • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
Lainey Merriwether
crwdns2935283:002/22/22crwdne2935283:0
662 crwdns2915208:0crwdne2915208:0
Clemson, Team 2-1, Hunter Spring 2022 crwdns2935289:0Clemson, Team 2-1, Hunter Spring 2022crwdne2935289:0
CLEM-HUNTER-S22S2G1
crwdns2936751:024crwdne2936751:0 9
crwdns2936753:07crwdne2936753:0 59
crwdns2936753:030crwdne2936753:0 224
crwdns2959996:0crwdne2959996:0 6,894
