Garmin DriveSmart 50 LMT Screen Replacement
    1. Garmin DriveSmart 50 LMT Screen Replacement, Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
    2. Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a plastic opening tool or metal spudger to separate the back cover from the front frame. Start from the corners and work your way around the device.
      • Carefully lift the back cover off to reveal the motherboard and ribbon cables.
    3. Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to unlock the screen cable ZIF connector.
      • Use angled sweezers to slide the cable from the socket.
      • You may need to flip the display assembly over for easier access to the display connector.
    4. Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin DriveSmart 50 LMT Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the screen does not lift easily, use an iOpener to soften the adhesive.
      • Use a nylon spudger to pry the old display assembly.
      • The screen is held in place with adhesive, so be careful when removing it to avoid bending the frame.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lydia Barrett
crwdns2935283:009/25/25crwdne2935283:0
463 crwdns2915208:0crwdne2915208:0
Texas Tech, Team 41-5, Allen Fall 2025 crwdns2935289:0Texas Tech, Team 41-5, Allen Fall 2025crwdne2935289:0
TTU-ALLEN-F25S41G5
crwdns2935297:036crwdne2935297:0
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 213
