Garmin Drive 60LM Motherboard Replacement
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
    we think the plastic spudger would work better. The metal spudger seems like overkill.
    Tommy Wiffler - crwdns2934203:0crwdne2934203:0
  3. Garmin Drive 60LM Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Garmin Drive 60LM Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
Andy Flores
crwdns2935283:001/30/17crwdne2935283:0
247 crwdns2915208:0crwdne2915208:0
Baylor, Team 3-3, Whitney Spring 2017 crwdns2935289:0Baylor, Team 3-3, Whitney Spring 2017crwdne2935289:0
BU-WHITNEY-S17S3G3
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - crwdns2934203:0crwdne2934203:0
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,532
