Use this guide to remove the battery from your GameSit T4 Pro controller. All you need for this repair is a Phillips #1 screwdriver and the iFixit opening tool. For the battery replacement, this controller requires a 600 maH battery. Complete this repair guide before continuing to the other repair guides.
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
Use your iFixit opening tool to break the seam of the back of your controller.
Using the plastic spudger, wiggle the connection out of place.
Apply a slow, but consistent pull to the old 600 maH battery.
Attach new battery onto the pad.
Battery Model is pl502450 600mah
3.7v
Where can I buy this battery? Do You have a link to it?
