GameSir G7 SE Rumble Motor Replacement
  1. GameSir G7 SE Rumble Motor Replacement, Interior face plate: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faceplate by prying upwards with a plastic opening tool.
    • This faceplate is magnetic and will be easy to come off.
  2. GameSir G7 SE Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Rumble Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
  3. GameSir G7 SE Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Rumble Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
    • Make sure to hold the controller upside down; otherwise the buttons will fall out.
  4. GameSir G7 SE Rumble Motor Replacement, Rumble Motor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you can see the internals of the controller, you need to remove the plug for the rumble motors. This plug is easy to remove and can be pulled straight out using your hands.
    • Use a pair of small pliers if you have difficulties.
  5. GameSir G7 SE Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GameSir G7 SE Rumble Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the plug is removed, you can easily pull out the rumble motor.
    • There is a left and right rumble motor, so be careful when replacing them. It is easy to differentiate them visually. Look for the size of the weights on the bottom; they will be different.
Memphis Collins
crwdns2935283:001/23/24crwdne2935283:0
284 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-6, Virtue Spring 2024 crwdns2935289:0Western Carolina University, Team 1-6, Virtue Spring 2024crwdne2935289:0
WCU-VIRTUE-S24S1G6
How to get a replacement part? Will those from Xbox 360 fit?
Redhair - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 673
