Addressing joystick wear or malfunction, this guide assists GameSir G7 SE owners in replacing their joystick modules. Common symptoms that necessitate this repair include drifting, sticking, or unresponsiveness, affecting game control accuracy.
Disconnect the controller from all power sources before beginning the repair to ensure safety. Troubleshooting page sections such as “Joystick Drift” or “Sticky Joystick” might offer additional insights before you start.
Remove the faceplate by prying upwards with a plastic opening tool.
Use a T6 Torx Screwdriver to remove the six 9 mm screws from the interior face plate.
Using a plastic spudger tool, remove the interior face plate. Go around all the edges, prying downwards until it's removed.
Remove the plastic joystick that is covering the joystick module by pulling up on from the gray grip.
Use a plastic spudger to gently bend the retention clips back.
Pull directly up on the joystick module to remove it from the motherboard.
What joystick module is compatible with the G7 SE, and is it of the same quality as the original?
Where to get the replacement parts?
Where do you get the replacement parts from?
Guida inutile senza ricambio
