Galaxy Note10 Plus Loudspeaker Replacement
Carsten Frauenheim
crwdns2944107:0crwdnd2944107:0Carsten Frauenheimcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Yan 17, 2025crwdne2944111:0
crwdns2931287:020crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to remove or replace the loudspeaker on your Samsung Galaxy Note10+.
Note: The daughterboard cover doubles as the main downwards-facing loudspeaker.
crwdns2944105:0crwdne2944105:0
  1. Galaxy Note10 Plus Loudspeaker Replacement, Heat the rear cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely power off your phone before you begin disassembly.
    • Prepare an iOpener and apply it to the left edge of the rear cover for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    I have an adjustable hot plate. I bought it when I replaced the back and battery on a previous note. I am wondering about some type of shim so that the camera bump is not in contact with the hot plate. I am thinking about fender washers. Is there a better way?
    Rusty Lingenfelter - crwdns2934203:0crwdne2934203:0
    I actually had my back plate come off by itself after I washed my phone after UV activated glue got on it. I used alcohol and that somehow got on contact with the glue and weakened it. Granted, it was a 6 year old phone with a cover and it did get hot from time to time, so that might have had something to do with the weakened glue. In any case, I'm upset I didn't use this opportunity to change my battery. Instead I just glued it back on :(
    Joe - crwdns2934203:0crwdne2934203:0
  2. Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the heated edge of the rear cover, as close to the edge as possible.
    • If your rear cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken cover.
    • Pull up on the suction cup with strong, steady force to create a gap between the rear cover and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  3. Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Begin to slice the adhesive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
    • Don't insert the opening pick more than halfway into the phone or you risk damaging internal components.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
  4. Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Slice around the perimeter of the phone: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    • The rear cover will begin to separate from the phone as you finish all sides of the phone.
    Be extremely carefull: rear cover is very fragile!
    Elbert Ainstein - crwdns2934203:0crwdne2934203:0
  5. Galaxy Note10 Plus Loudspeaker Replacement, Lift off the rear cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Lift off the rear cover: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the rear cover straight up to remove it.
    • Follow this guide to reinstall the rear cover and replace the adhesive.
    • Be sure to turn on your device and test your repair before installing new adhesive and resealing the device.
    • If you're using Tesa tape to reattach components, follow this guide.
    Muy buena la guia. nada que añadir. para montar solo limpia el equipo donde estaba el tape anterior, y remoueve los el tape de la tapa nueva solo ponla y listo…
    Manuel carrion - crwdns2934203:0crwdne2934203:0
  6. Galaxy Note10 Plus Loudspeaker Replacement, Lift up the metal cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
  7. Galaxy Note10 Plus Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
  8. Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the battery: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
  9. Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the wireless charging coil: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Disconnect the wireless charging coil: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
  10. Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Remove the wireless charging coil: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the metal shielding up so you can grip it with your fingers.
    • Peel the wireless charging coil up and away from the device.
    • The wireless charging coil is secured to the phone with some light adhesive.
    • Remove the wireless charging coil.
    Can you reuse the wireless charging coil? I don’t see a replacement on the site. I just learning all this.
    Jon Marble - crwdns2934203:0crwdne2934203:0
  11. Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker screws: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
  12. Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Galaxy Note10 Plus Loudspeaker Replacement, Remove the loudspeaker: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to remove the loudspeaker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Carsten Frauenheim
148,665 crwdns2915208:0crwdne2915208:0
crwdns2935297:0438crwdne2935297:0
Staff
crwdns2931471:0118crwdne2931471:0
crwdns2935297:022,508crwdne2935297:0
Grazie per la guida, ho sostituito l'altoparlante e il cellulare è come nuovo
Roberto Di Santolo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 3,139
