GE Side-By-Side Refrigerator Evaporator Fan Replacement
  1. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unplug your refrigerator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice bin: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice bin: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice bin: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grasp the ice bin and lift it upward slightly.
    • Pull the bin out of the freezer compartment and remove it.
  3. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice maker cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice maker cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove ice maker cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the front edge of the cover 1cm (1/2") and pull the cover out of the freezer compartment.
  4. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten ice maker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to loosen or remove the two screws securing the ice maker in place.
  5. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice maker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice maker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice maker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the icemaker upward to allow the mounting keyholes to slip over the screw heads.
  6. GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Reposition the ice maker to the lower right, below the auger motor.
    • You may be able to rest it on a lower shelf.
    • The ice maker is still connected to the electrical supply. Don't try to remove it yet.
  7. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect ice maker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect ice maker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect ice maker: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect ice maker plug by loosening the retainer clips by lifting them if possible and then pulling the plug out of the socket. The socket is shown with the plug removed.
    • This may take some force. You can try lifting the retainer clips with a small flat head screwdriver, but access is difficult.
    • Remove the ice maker from the freezer compartment.
  8. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the ice auger motor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the two screws securing the ice auger motor to its support brackets.
  9. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Free the ice auger motor from its support brackets: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Free the ice auger motor from its support brackets: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Free the ice auger motor from its support brackets: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the ice auger motor to the right to free it from the left hand support bracket.
    • Lower the ice auger motor to the left, forward and down to allow it to clear the right hand support bracket.
  10. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice auger motor assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice auger motor assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the ice auger motor assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lower the auger motor assembly so that you can access the electrical connection.
  11. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect and remove the ice auger motor assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect and remove the ice auger motor assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect and remove the ice auger motor assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The ice auger motor connection is mounted at an angle.
    • Squeeze the locking tabs on the connector to release it from the socket and pull it out to disconnect it.
    • Remove the ice auger motor assembly.
  12. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove shelves.: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove shelves.: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the right edge of the shelf to free it from the clips which secure it.
    • This may take a bit of force as the clips hold firmly
    • Once the shelf is lifted, move it to the right and free the tabs on the left edge.
    • Remove the shelf.
    • Repeat this for each of the freezer shelves.
  13. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the light bulb: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the light bulb: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the light bulb and set it aside.
  14. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the lower evaporator cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a #2 Phillips screwdriver to remove the retaining screws securing the lower evaporator cover.
  15. GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower evaporator cover by pulling it toward you and then rotating it so it will get past the shelf brackets.
  16. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the evaporator fan cover: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the four screws securing the evaporator fan cover to the rear of the refrigerator.
  17. GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the evaporator fan cover upward to free it.
    • Pull the top of the evaporator fan cover forward.
  18. GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the evaporator fan cover.
  19. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the ground connection: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the ground connection: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 1/4" nut driver to disconnect the ground connection next to the evaporator fan housing.
  20. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the right hand cable: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the right hand cable: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the right hand cable: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the release tabs on the connector located to the right of and above the evaporator fan housing.
    • Pull the connector toward you to disconnect it.
  21. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the left hand cable: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the left hand cable: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable located above and to the left of the evaporator fan housing, by squeezing the locking tabs and pulling out the connector.
  22. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan housing: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan housing: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan housing: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 1/4" nut driver to loosen or remove the screws securing the fan housing to the rear wall of the freezer.
    • If you loosened the screws, lift the fan housing until the screws are freed from the slots.
  23. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the evaporator fan housing: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the evaporator fan housing: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the evaporator fan housing: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reposition the evaporator fan housing by lifting it and rotating the top toward you to access the evaporator fan assembly retainer screws.
  24. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermostat: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermostat: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermostat: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Defrost thermostat location
    • Pull the defrost thermostat upward to unclip it from the evaporator tubing.
  25. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermistor: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermistor: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the defrost thermistor: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Defrost thermistor location
    • Unclip the defrost thermistor from the evaporator tubing..
  26. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the heater wires: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unclip the heater wires: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip both of the heater wires from their foam restraints located near the sides of the evaporator coil to allow the evaporator fan housing to move more freely.
  27. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Unfasten the evaporator fan motor assembly: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 1/4" nut driver to remove the two screws securing the evaporator fan motor assembly to the evaporator fan housing.
  28. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Reposition the evaporator fan assembly: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the evaporator fan motor assembly from the fan housing.
    • Don't try to completely remove this assembly as it is still connected by several wires to the fan housing
  29. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan assembly: crwdns2935265:029crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Disconnect the evaporator fan assembly: crwdns2935265:029crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the fan wires from the retaining clip on the fan housing.
  30. GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the locking tabs to release the connector, and pull it apart to disconnect the evaporator fan assembly.
  31. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove evaporator fan motor retainer bracket screws: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove evaporator fan motor retainer bracket screws: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove evaporator fan motor retainer bracket screws: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Fan bracket screw locations are indicated by arrows.
    • Use a 1/4" nut driver to remove the fan bracket screw that also secures the grounding connection.
    • Use the same 1/4" nut driver to remove the remaining fan bracket screw. The screw location is shown.
  32. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove fan retainer bracket: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove fan retainer bracket: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the evaporator fan retainer bracket.
  33. GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the evaporator fan blades: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GE Side-By-Side Refrigerator Evaporator Fan Replacement, Remove the evaporator fan blades: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of pliers as a lever to lift the fan blades and slide them off the shaft of the evaporator fan motor.
    • You can now replace the evaporator fan motor.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,786 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,567crwdne2935297:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 100
crwdns2936753:030crwdne2936753:0 336
crwdns2942667:0crwdne2942667:0 1,510
