GD Midea FT30-3D Motor Replacement
Alan Su
crwdns2944107:0crwdnd2944107:0Alan Sucrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 1, 2021crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
This installation guide will demonstrate how to remove all of the components around the main fan blade motor.
  1. GD Midea FT30-3D Motor Replacement, Fan Blades: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement, Fan Blades: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Release the 3 clips that attach the front fan guard to the rear fan guard.
    • Notice: The lower connecting bracket is NOT a clip. It acts as a mounting alignment bracket for the front fan guard.
  2. GD Midea FT30-3D Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the front fan guard off.
  3. GD Midea FT30-3D Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the spinner from the center of the fan blade.
    So how do i take the spinner off the fan
    Martha Meza - crwdns2934203:0crwdne2934203:0
    H how do I take the spinner off the center of a fan I don't know how
  4. GD Midea FT30-3D Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The fan blades should now be easy to lift up.
    • When reassembling the fan make sure the notches in the center of the fan blade line up with the protrusions in the motor's shaft.
  5. GD Midea FT30-3D Motor Replacement, Oscillation Mechanism: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rear fan guard by taking off the plastic nut that holds the rear fan guard to the upper assembly.
    • The plastic nut needs to be twisted off; like a screw.
  6. GD Midea FT30-3D Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw at the center of the oscillator knob and remove the oscillator knob.
    • If the oscillator knob is clean and undamaged then the problem is with the oscillator. If the knob is damaged replace it and test your fan before proceeding forward in the guide.
  7. GD Midea FT30-3D Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front motor housing by removing 4 screws.
  8. GD Midea FT30-3D Motor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The main motor housing can be taken off by removing a single screw at the back of the upper assembly.
  9. GD Midea FT30-3D Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There is a capacitor attached to the oscillator by a single screw. Once the screw is removed the capacitor should come off easily.
    the two wires of capacitors are connected where ?? please guide me.
    mohangmysore - crwdns2934203:0crwdne2934203:0
    The two wires are normally connected to the motors, start winding.
    james - crwdns2934203:0crwdne2934203:0
  10. GD Midea FT30-3D Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw that connects the oscillator to the rocker arm.
    • Push down on the rocker arm after removing the screw and turn it away from the oscillator.
  11. GD Midea FT30-3D Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The oscillator should now be easy to pull off.
    • Clean the oscillator and remove any jams. If the problem persists the oscillator is damaged and needs to be replaced.
  12. GD Midea FT30-3D Motor Replacement, Motor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GD Midea FT30-3D Motor Replacement, Motor: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the base of the upper assembly there is a plug which conceals a screw.
    • The plug can be removed with a screwdriver. Removing the plug may take a few attempts.
  13. GD Midea FT30-3D Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the motor out of the base of the upper assembly.
crwdns2935229:010crwdne2935229:0
Alan Su
crwdns2935283:010/03/12crwdne2935283:0
834 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 24-28, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 24-28, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S24G28
Alan Su (y contribuidores): Excelente aporte!!! Felicidades me ha sido muy útil. Gracias
Oliver K - crwdns2934203:0crwdne2934203:0
Hey. Could you tell me where to buy the spare motor from please?
Hywel Williams - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 7,670
