Fusion5 5.5 Gen II Front & Rear Camera Replacement
  1. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold the device with the screen facing away from you and the back of the device facing you.
    • Locate the groove at the bottom corner of the device.
    • Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
  2. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fusion5 5.5 Gen II Front & Rear Camera Replacement, Midframe: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove thirteen 3mm Phillips #00 screws from the midframe.
    • Remove the single 5mm Phillips #0 screw below the camera.
  3. Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening pick, begin prying one of the top corners to remove the midframe from the device.
    • Be careful not to damage the cables inside the device when you pry the midframe off.
  4. Fusion5 5.5 Gen II Front & Rear Camera Replacement, Front & Rear Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, flip the brown tab securing the ribbon cable.
    • Make sure to only lift the flap and not the connector socket due to its susceptibility to break off.
  5. Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tweezers, grab the ribbon cable and pull it out from its connector.
    • Then pull the front camera component out of its socket on the motherboard.
  6. Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, grasp the ribbon cable's metal tab and gently lift it to disconnect it from its connector on the motherboard.
    • Make sure to only lift by the metal tab and not the connector socket due to its susceptibility to break off.
  7. Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fusion5 5.5 Gen II Front & Rear Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You may now grab and lift the rear-facing camera out of its socket on the motherboard.
Hwajin
crwdns2935283:009/16/19crwdne2935283:0
566 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S8-G1, Salas Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S8-G1, Salas Fall 2019crwdne2935289:0
ERAU-SALAS-F19S8G1
crwdns2942667:0crwdne2942667:0 438
