Fujitsu LIFEBOOK P7010D Hard Drive Replacement
  1. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the laptop upside down on a table.
    Place the laptop upside down on a table. (to the point...)
    Bruce - crwdns2934203:0crwdne2934203:0
    Why is it asking me for a second comment?
  2. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery (the grey block). Find the two tabs on one end of the battery, as pictured.
    • Using two fingers, press both tabs down at once until they are fully depressed.
  3. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • While holding the tabs down, slowly pivot the battery up.
    • The battery is now free and safe to pull out.
  4. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Disc Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the tab down as far as possible using your finger or opening tool to unlock the disc drive.
    • While still holding the tab down, use your other hand to pull out the disc drive straight out of its place.
  5. Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement, Hard Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the bottom of the laptop, find the two bottom-plate screw holes near the disc drive. Parallel to them is a 2.4mm screw (second photo).
    • After locating the 2.4mm screw, use a Phillips #0 screwdriver to unscrew it.
  6. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Anti-Static Wrist Strap
    $7.16
    • Flip the laptop over and open it facing you.
    • The cover is connected to the inner computer with an aluminum strip, so be careful lifting it.
    • Use a plastic opening tool to lift the bottom black cover on both sides.
    • For the proceeding steps, put on an anti-static wrist strap to protect the delicate circuitry inside the computer. To learn how to use the anti-static wrist strap, click here.
  7. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The hard drive is connected with a strip, so be careful when lifting it out.
    • Once the black cover is lifted, gently flip it and set it on the keyboard.
    • Locate the disc drive on the right side, as pictured.
    • Using two fingers and the clear plastic handles on the top, gently lift it out. Place it on the side of the laptop.
  8. Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Fujitsu LIFEBOOK P7010D Hard Drive Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the hard drive on its side.
    • The pins connected to the hard drive are extremely fragile. Take care in handling the next few steps.
    • Hold the hard drive and insert a plastic opening tool, preferably a wider one, in between the black pin holder and the hard drive.
    • Gently wiggle the black pin holder back and forth, on each side, until it comes off.
Nicholas Ross
crwdns2935283:001/20/12crwdne2935283:0
207 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-31, Amido Winter 2012 crwdns2935289:0Cal Poly, Team 10-31, Amido Winter 2012crwdne2935289:0
CPSU-AMIDO-W12S10G31
crwdns2935297:021crwdne2935297:0
hai sir..please help me..how to replacement hdd lifebook PH770/5AN ? can you answer to my email antogantengnian@gmail.com..thanks a lot
anto adhitya - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 5,656
