Fujifilm Finepix S1800 Top Cover Replacement
  1. Fujifilm Finepix S1800 Top Cover Replacement, Back Cover Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
  2. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
  3. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
  4. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
    • The cover will pop out.
    • You may have to work the back cover from different sides to get it to pop off.
  5. Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1800 Top Cover Replacement, LCD Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
    • Gently lift the back cover away from the device.
    • Do not pull or yank free. The LCD screen is connected to the motherboard via a small ribbon cable.
  6. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the lever to disconnect the ribbon cable from the circuit board.
    • Do not rip the fragile micro ribbon cable.
  7. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the LCD screen.
    • Do not touch the screen directly.
  8. Fujifilm Finepix S1800 Top Cover Replacement, Top Cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the flash.
    • Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
  9. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
  10. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Switch the lever to disconnect the micro strip that connects the top plate.
    • Do not rip the micro strip.
    The second photo is after the top cover is removed. I’m repairing a s1600. The lens is stuck. But this guide and inside looks almost 100% the same as my s1600. Only thing is: i can’t remove the top cover. Removed all the same screws but the only difference is the lcd has no screws. Anyway the only screws I haven’t removed are the once inside the battery case (the 2 extra in the flash, not done here are also removed) Anyway the topcover looks stuck. And i’m going to try a plastic prying tool. The battery screws are very short. Maybe they are the problem but they look like they only hold the spring bumpers for battery. It must be difficult to put these bumpers back. But I must say I did 1. And the bumper is not falling out. So try those 3 screws first and then pry open the top.
    Rogier Keller - crwdns2934203:0crwdne2934203:0
  11. Fujifilm Finepix S1800 Top Cover Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top cover.
Ryan Rockford
crwdns2935283:002/15/17crwdne2935283:0
618 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-6, Eyestone Spring 2017 crwdns2935289:0USF Tampa, Team 8-6, Eyestone Spring 2017crwdne2935289:0
USFT-EYESTONE-S17S8G6
I had a problem with my Fuji Fine pix S 2950 (similar case) On / Off switch, this guide was invaluable to help me get into the top case moulding.
The fault was a crack around a solder pad were the SMT switch is mounted on the PCB , a simple solder job but an absolute bugger to get to.
Thank you for this simple and straight forward guide.
Bob Wilkins - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 723
